I’ve had a Pironman5 since maybe September. Mainly playing around with it, eventually planning to use it for some simple backups from Windows via robocopy, as well as a Plex server. I do have an NVME card, and all has worked fine up until recently.
It is not something I use daily at this point, but it is in my server closet connected directly to a switch via cat6 cables. I login over ssh when needed, or more rarely, via VNC.
I recently tried a robocopy and it failed. I soon realized the Pi5 was not up. The Pi is plugged in, same as it has been since September. All that is on is the red light on the main board. It does not power on.
Oddly, and one thing I did not really see mentioned in the other numerous threads, is when I touch some of the pins (specifically the #6 and #12) exposed from the HAT+ on the right side, the fans spin up. It still does not power on, but when I touch the pins an amber light appears on the HAT+ close to where the two regular USB ports are on the back.
Is any of this indicative of a bad USB HDMI adapter?
