Pironman 5 Max NVMe Anything larger than 2 TB?
What is the maximum size of memory for the Pironmam 5 max. Can it be greater than 2 TB? If not, I have another question. Can you dumb down an 8 TB that’s 4x of 2 TB modules in one stick of memory? Is there compatible software to do this?
Regarding the memory size of the Pironman 5 Max, there may be a key misunderstanding. The Pironman 5 Max itself is not an independent device but a case designed specifically for the Raspberry Pi 5, and it does not provide or limit memory (RAM) capacity.
The Pironman 5 Max does not support RAM expansion; its memory size is determined by the built-in Raspberry Pi 5.
However, it supports expanded storage space, with great potential. It is possible to achieve a total storage capacity exceeding 2TB, even reaching up to 16TB, by installing two high-capacity M.2 SSDs.
