ray068
October 17, 2025, 5:15am
I have the standard raspberry pi 5 running off a 64 GB sd card
and also a Pironman running from a I TB SSD
But when I run free from the command terminal, it gives much the same information.
I would of thought it would give a extra 1TB from the Pironman
To help us diagnose your issues more effectively, could you please provide a video or pictures showing the problems?
If the video memory is large, please upload the recorded video to onedrive, share the video link with us, and give us access permissions
ray068
October 17, 2025, 7:41am
When I use free
By The Way from lsb_release -a
I am using Debian release 12
codename bookworm
total used free shared buff/cache available
Mem: ………… 8255688 … 1629888…… 2814932……338960 ……4034144…… 6626800
Swap: ………… 524272…………0…………524272
I hope this will help maybe I am using wrong terminal command.
The command you used checks the RAM usage on your Raspberry Pi.
If you want to check the disk storage, please run:
df -h
To view the capacity and available space of your SSD, please run:
lsblk
ray068
October 17, 2025, 11:58am
OK those two commands makes a differance
That has fixed that query.
Thank you for the help
