Pi Config Wizard installed as per documentation as well as the Pironman addon.
All LEDs are working fine including the M.2 HAT
Not sure if related; but after a few reboots and testing everything, I got the following error in the dasboard for pironman 5
(error only occured once)
25/01/24 21:53:01.665 [WARNING] Failed to create gpiochip4 symlink
Thanks for the feedback, this is not a common issue, can you send us a screenshot of the error message and we will try to reproduce the issue and fix it.
Unfortunately I did not manage to get a screenshot prior to wiping the pi.
Also, after getting everything working I just checked the error log and moved on. I have noted the log clears quite rapidly. I did not go looking for a log file for history and I could not see in your documentation where the log file is kept.
If you share that then I will check my updated install for you.
Finally : now that it’s working I’m very impressed with your product. I love the fact that I have the fans coming in at 50degC and all the colours. The build quality is great but I was worried a few times about making a correct connection with the flimsy ribbon cables : I did not want to dismantle this thing afterwards!!
The battery though : how are we going to replace it once it dies in a few years? Please put that in your FAQ section!
FYI: I had to disconnect the hdd in order to change the boot sequence : this is a limitation of home assistant and not yours. Fortunately the ribbon cable was reachable after removing the side panel 4 screws and operation was pretty easy. Now that I have debian installed I don’t have this limitation any longer (HAOS is in a docker container)
