Hi, I’m new to the industry, greetings, brought myself a Pironman 5 Rasberry pi 5 8GB back in January, assembled the Pironman 5 with no prior experience following the instructions that came along with the Pironman 5 & a tutorial I came across on the sunfounder YouTube channel, initial boot was via sd card, ran sudo apt update/upgrade, then went on to install the Pironman 5 software following the simple instructions from the sunfounder website, after a reboot fans leds & oled screen came into effect, i used the sd card copier under accessories copied the sd card to nvme, ran sudo raspi-config advanced options changed the boot order to boot from nvme, advanced options again to enable gen 3, after a reboot Pironman 5 worked fine with no complications. Kind regards.
Indeed. When a project goes smoothly as expected, it can make the whole person feel better.
Thank you very much for your support and wish you a happy life!
