Pironman 5 module software
Has anyone got this running when using Batocera works fine running pios
Batocera version 2024-07-31 was tested on pironman5 and the program is fully compatible. What version of Batocera are you using and are you reporting any errors when installing the pironman5 program?
I’m running 2024-07-31 I get screen to work but how do I change the rgb colours
If the rgb doesn’t light up it may be that the spi is not turned on correctly, you can modify the /boot/config.txt file to start the spi, add dtparam=spi=on at the end of the file and reboot.
To modify the rgb style, you can use the pironman5 command, for example:
pironman5 -rs flow
pironman5 -rc 0a0101
pironman5 restart
Easiest way to modify the config file as never done this before thanks
