Thank you for your patience. Based on our investigation, this issue is related to a compatibility problem after upgrading to kernel 6.12.96 — this kernel version has a gpiochip compatibility issue that prevents the pironman5 service from accessing the GPIO correctly, which causes the fan to lose control and run at full speed. The dependency update command you ran is a solution we tested previously, but we still need to confirm why fan control has not been restored.
Please proceed as follows:
If you have not rebooted the Raspberry Pi since running the dependency update, please reboot first:
sudo reboot
If the fan is still running at full speed after the reboot, please provide the full output of the following commands:
uname -r
sudo systemctl status pironman5 --no-pager -l
sudo journalctl -u pironman5 -b -n 100 --no-pager
Also, could you confirm whether the fan running at full speed is the case RGB fan or the CPU cooling fan? They are driven by different control logic, so knowing which one helps us locate the issue faster.
This information will help us check the service status after the update and whether fan control is still reporting errors. Once we receive it, we will get back to you with the next steps as soon as possible.
Thank you for your cooperation, and please feel free to reach out if you have any other questions.
We have reproduced the issue you reported and confirmed that it is caused by the Pironman 5 software version, which affects OLED screen and fan control. A fixed version has now been released. Please re-run the following installation command to upgrade:
