I just received my Pironman 5 Pro Max. I do really like the setup. It was easy.
The issue I noticed that one monitor can be set to 3840x2160 but the second monitor can only be set to 1920x1080. The DSI monitor is set to 800x400.
My Pironman 5 Pro drives two HDMI ports at 3840x2160.
I have tried to swap cables around to see if it follows the cable or not. Cables that can display 3840x2160 on Pironman 5 Pro can not on the Pironman Pro Max. I tried to remove the DSI monitor and it can still only drive 1 monitor at 3840x2160 the second HDMI port is at 1920x1080
So the cables and monitors appear to be good (on the Pironman 5 Pro) and fails on Pironman 5 Pro max.
All of the software has been installed. Everything else works for the most part. (the only other issue is the LEDs on one of the fans).
I plan to write up the LEDs in another thread. I wanted this one for the HDMI ports.
