I finished building my Pro Max case today. It booted up just fine. Installed the Pironman software with the following:
cd ~
git clone -b pro-max GitHub - sunfounder/pironman5: Code for Raspberry Pi 5 case (Pironman5) Β· GitHub --depth 1
cd ~/pironman5
Rebooted, no LEDs or fans were working.
Took the case apart and verified that every connection was secure and in its proper place.
Flashed a clean Raspbian to the SSD. Installed the Pironman service using the following:
kc5jim@Pi-5-16GB-Pro-Max:~/pipower5 $ curl -sSL βhttps://raw.githubusercontent.com/sunfounder/sunfounder-installer-scripts/main/pironman5/install.shβ -o install.sh
kc5jim@Pi-5-16GB-Pro-Max:~/pipower5 $ sudo bash install.sh --pipower5
βββββββ ββββββββββ βββββββ ββββ βββββββ ββββ ββββββ ββββ βββ ββββββββ
βββββββββββββββββββββββββββββββββ ββββββββ ββββββββββββββββββ βββ ββββββββ
ββββββββββββββββββββββ βββββββββ ββββββββββββββββββββββββββββ βββ ββββββββ
βββββββ ββββββββββββββ ββββββββββββββββββββββββββββββββββββββββββ ββββββββ
βββ ββββββ βββββββββββββββ βββββββββ βββ ββββββ ββββββ ββββββ ββββββββ
β Install pipower5
β Install spc
β Create pipower5 symlink
Create symlinks
β Create pironman5 symlink
Setup shell completion
β Register bash completion
Setup auto-start
β Install service file
β Enable pironman5 service
β Reload systemd
Configure kernel modules
β Add module i2c-dev
Copy device tree overlays
β Copy sunfounder-pironman5promax.dtbo
β Copy PiPower5 device tree overlay
Finalize permissions
β Set execution permission on work dir
β Set final ownership
Write product variant
β Ensure work directory exists
β Write variant identifier
β Write custom module
Install finished.
Do you want the browser to open automatically on desktop startup?
This will install an autostart entry that launches the Pironman 5 dashboard in a browser.
Install auto-launch browser? [Y/n]:
File β/home/kc5jim/pironman5/pironman5/_launch_browser.pyβ, line 8, in
from ._constants import CONFIG_PATH
ImportError: attempted relative import with no known parent package
Do you want to reboot now? (y/n)
Still no fans or LEDs
Rebooted, puff of smoke from the area of the fan interface with the Pi. Pi shuts down. Now the only thing the Pi does is light up the red LED solid. Power Supply is the official Raspberry Pi 5 Power Supply.
Removed the Pi from the case, still only gives the solid red LED. Used a new SD card. Same results. Iβm guessing the CPU fan failing to turn on cooked the Pi.
