I just assembled a Pironman-v2 for my Raspberry Pi 4. However, I’m having the following issues:
- The fan does not work even when setting the temperature below the current reported temperature of the PI
- Power button doesn’t trigger safe shutdown.
- LED screen doesn’t work.
I tried disassembling the accessory and reseating the LED ribbon cable but this didnt resolve the issue.
The log:
OS Version:
Description: Debian GNU/Linux 12 (bookworm)
PCB info:
Revision : c03112
Model : Raspberry Pi 4 Model B Rev 1.2
24/02/16 16:41:05,318 [DEBUG] power_key_pin : 16
24/02/16 16:41:05,319 [DEBUG] fan_pin : 6
24/02/16 16:41:05,319 [DEBUG] update_frequency : 0.5
24/02/16 16:41:05,319 [DEBUG] temp_unit : C
24/02/16 16:41:05,319 [DEBUG] fan_temp : 30.0
24/02/16 16:41:05,319 [DEBUG] screen_always_on : False
24/02/16 16:41:05,319 [DEBUG] screen_off_time : 60
24/02/16 16:41:05,319 [DEBUG] rgb_enable : True
24/02/16 16:41:05,319 [DEBUG] rgb_switch: True
24/02/16 16:41:05,320 [DEBUG] rgb_style : breath
24/02/16 16:41:05,320 [DEBUG] rgb_color : 0a1aff
24/02/16 16:41:05,320 [DEBUG] rgb_blink_speed : 50
24/02/16 16:41:05,320 [DEBUG] rgb_pwm_freq : 1000
24/02/16 16:41:05,320 [DEBUG] rgb_pin : 10
24/02/16 16:41:06,359 [DEBUG] oled init failed:
[Errno 110] Connection timed out
24/02/16 16:41:06,371 [DEBUG] rgb_show
24/02/16 16:41:06,371 [DEBUG] rgb_show: breath
Temperature
bash$ /usr/bin/vcgencmd measure_temp
temp=44.8’C
Has anyone encountered this? This seems like it may be a hardware issue but I’m not sure.
