Hello
Everything else appears to be working on my Pironman V2 except my RGB lights.
They worked for a couple of hours and then stopped. Could they be defective?
I am including my config file and log file for diagnosis purposes.
Thanx
L
[all]
power_key_pin, gpio pin to power key,default pin 26 (BCM)
fan_gpio, gpio pin to switch fan, default pin 6 (BCM)
temp_unit, the unit of temperature, [ C / F ] (Celsius/Fahrenheit)
fan_temp, temperature at which the fan switches on,
in celsius (default 50),in range (30 ~ 80)
screen_off_time, screen off after <screen_off_time> seconds
always_on, [on/off], whether the screen is always on, default False
rgb_enable, rgb strip enable
rgb_style, rgb strip display style, in [breath / static /leap / flow / raise_up / colorful / colorful_static]
rgb_color, color of the RGB indicator inside the case
rgb_blink_speed, rgb color change speed (0 ~ 100, default 50)
rgb_pwm_freq, rgb signal frequency (400 ~ 1600, default 1000 kHz)
rgb_pin, rgb signal pin, could be 10(spi), 12(PWM) or 21(PCM)
temp_unit = C
fan_temp = 60
screen_always_on = True
screen_off_time = 60
rgb_enable = True
rgb_style = breath
rgb_color = 0a1aff
rgb_blink_speed = 50
rgb_pwm_freq = 1000
rgb_pin = 10
------------------------24/07/06 11:07:31------------------------
pironman version: 2.2.8
username: dad
username: dad
Kernel Version:
Linux pi4a 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
OS Version:
No LSB modules are available.
Description: Debian GNU/Linux 11 (bullseye)
PCB info:
Revision : c03114
Model : Raspberry Pi 4 Model B Rev 1.4
24/07/06 11:07:31,630 [DEBUG] power_key_pin : 16
24/07/06 11:07:31,630 [DEBUG] fan_pin : 6
24/07/06 11:07:31,631 [DEBUG] update_frequency : 0.5
24/07/06 11:07:31,631 [DEBUG] temp_unit : C
24/07/06 11:07:31,631 [DEBUG] fan_temp : 50.0
24/07/06 11:07:31,631 [DEBUG] screen_always_on : False
24/07/06 11:07:31,632 [DEBUG] screen_off_time : 60
24/07/06 11:07:31,632 [DEBUG] rgb_enable : True
24/07/06 11:07:31,632 [DEBUG] rgb_style : breath
24/07/06 11:07:31,632 [DEBUG] rgb_color : 0a1aff
24/07/06 11:07:31,632 [DEBUG] rgb_blink_speed : 50
24/07/06 11:07:31,632 [DEBUG] rgb_pwm_freq : 1000
24/07/06 11:07:31,632 [DEBUG] rgb_pin : 10
24/07/06 11:07:31,644 [DEBUG] rgb_strip init success
PCB info:
Revision : c03114
24/07/06 11:07:31,651 [DEBUG] power_key_pin : 16
24/07/06 11:07:31,652 [DEBUG] fan_pin : 6
24/07/06 11:07:31,653 [DEBUG] update_frequency : 0.5
24/07/06 11:07:31,654 [DEBUG] temp_unit : C
24/07/06 11:07:31,654 [DEBUG] fan_temp : 50.0
24/07/06 11:07:31,655 [DEBUG] screen_always_on : False
24/07/06 11:07:31,656 [DEBUG] screen_off_time : 60
24/07/06 11:07:31,656 [DEBUG] rgb_enable : True
24/07/06 11:07:31,657 [DEBUG] rgb_style : breath
24/07/06 11:07:31,658 [DEBUG] rgb_color : 0a1aff
24/07/06 11:07:31,658 [DEBUG] rgb_blink_speed : 50
24/07/06 11:07:31,658 [DEBUG] rgb_pwm_freq : 1000
24/07/06 11:07:31,659 [DEBUG] rgb_pin : 10
24/07/06 11:07:31,674 [DEBUG] rgb_strip init success
24/07/06 11:07:31,674 [DEBUG] close_rgb in sys.argv
24/07/06 11:07:31,675 [DEBUG] rgb_strip clear
24/07/06 11:07:31,762 [DEBUG] oled init success
24/07/06 11:07:31,795 [DEBUG] rgb_show
24/07/06 11:07:31,799 [DEBUG] rgb_show: breath
24/07/06 11:07:31,910 [DEBUG] Get IP: 192.168.232.210
24/07/06 11:12:53,500 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
------------------------24/07/06 11:13:35------------------------
username:
username:
Kernel Version:
OS Version:
OS Version:
PCB info:
Revision : c03114
24/07/06 11:13:36,083 [DEBUG] power_key_pin : 16
24/07/06 11:13:36,084 [DEBUG] fan_pin : 6
24/07/06 11:13:36,084 [DEBUG] update_frequency : 0.5
24/07/06 11:13:36,084 [DEBUG] temp_unit : C
24/07/06 11:13:36,084 [DEBUG] fan_temp : 50.0
24/07/06 11:13:36,085 [DEBUG] screen_always_on : False
24/07/06 11:13:36,085 [DEBUG] screen_off_time : 60
24/07/06 11:13:36,085 [DEBUG] rgb_enable : True
24/07/06 11:13:36,085 [DEBUG] rgb_style : breath
24/07/06 11:13:36,086 [DEBUG] rgb_color : 0a1aff
24/07/06 11:13:36,086 [DEBUG] rgb_blink_speed : 50
24/07/06 11:13:36,086 [DEBUG] rgb_pwm_freq : 1000
24/07/06 11:13:36,086 [DEBUG] rgb_pin : 10
PCB info:
Revision : c03114
24/07/06 11:13:36,091 [DEBUG] power_key_pin : 16
24/07/06 11:13:36,092 [DEBUG] fan_pin : 6
24/07/06 11:13:36,092 [DEBUG] update_frequency : 0.5
24/07/06 11:13:36,092 [DEBUG] temp_unit : C
24/07/06 11:13:36,092 [DEBUG] fan_temp : 50.0
24/07/06 11:13:36,092 [DEBUG] screen_always_on : False
24/07/06 11:13:36,092 [DEBUG] screen_off_time : 60
24/07/06 11:13:36,092 [DEBUG] rgb_enable : True
24/07/06 11:13:36,093 [DEBUG] rgb_style : breath
24/07/06 11:13:36,093 [DEBUG] rgb_color : 0a1aff
24/07/06 11:13:36,093 [DEBUG] rgb_blink_speed : 50
24/07/06 11:13:36,093 [DEBUG] rgb_pwm_freq : 1000
24/07/06 11:13:36,093 [DEBUG] rgb_pin : 10
24/07/06 11:13:36,098 [DEBUG] rgb_strip init success
24/07/06 11:13:36,098 [DEBUG] close_rgb in sys.argv
24/07/06 11:13:36,098 [DEBUG] rgb_strip clear
24/07/06 11:13:36,104 [DEBUG] rgb_strip init success
24/07/06 11:13:36,373 [DEBUG] oled init success
24/07/06 11:13:36,417 [DEBUG] rgb_show
24/07/06 11:13:36,418 [DEBUG] rgb_show: breath
24/07/06 11:13:36,494 [DEBUG] Get IP: 192.168.232.210
24/07/06 11:16:26,787 [DEBUG] POWER OFF
24/07/06 11:16:26,907 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
------------------------24/07/06 11:15:55------------------------
username:
username:
OS Version:
PCB info:
Revision : c03114
24/07/06 11:15:55,360 [DEBUG] power_key_pin : 16
24/07/06 11:15:55,360 [DEBUG] fan_pin : 6
24/07/06 11:15:55,360 [DEBUG] update_frequency : 0.5
24/07/06 11:15:55,360 [DEBUG] temp_unit : C
24/07/06 11:15:55,360 [DEBUG] fan_temp : 50.0
24/07/06 11:15:55,361 [DEBUG] screen_always_on : False
24/07/06 11:15:55,361 [DEBUG] screen_off_time : 60
24/07/06 11:15:55,361 [DEBUG] rgb_enable : True
24/07/06 11:15:55,361 [DEBUG] rgb_style : breath
24/07/06 11:15:55,361 [DEBUG] rgb_color : 0a1aff
24/07/06 11:15:55,361 [DEBUG] rgb_blink_speed : 50
24/07/06 11:15:55,361 [DEBUG] rgb_pwm_freq : 1000
24/07/06 11:15:55,361 [DEBUG] rgb_pin : 10
24/07/06 11:15:55,372 [DEBUG] rgb_strip init success
24/07/06 11:15:55,373 [DEBUG] close_rgb in sys.argv
24/07/06 11:15:55,373 [DEBUG] rgb_strip clear
24/07/06 11:15:55,582 [DEBUG] oled init success
24/07/06 11:15:55,615 [DEBUG] rgb_show
24/07/06 11:15:55,616 [DEBUG] rgb_show: breath
24/07/06 11:15:55,689 [DEBUG] Get IP: 192.168.232.210
------------------------24/07/06 15:17:27------------------------
username:
username:
Kernel Version:
OS Version:
OS Version:
PCB info:
Revision : c03114
24/07/06 15:17:27,361 [DEBUG] power_key_pin : 16
24/07/06 15:17:27,361 [DEBUG] fan_pin : 6
24/07/06 15:17:27,361 [DEBUG] update_frequency : 0.5
24/07/06 15:17:27,361 [DEBUG] temp_unit : C
24/07/06 15:17:27,361 [DEBUG] fan_temp : 50.0
24/07/06 15:17:27,361 [DEBUG] screen_always_on : False
24/07/06 15:17:27,361 [DEBUG] screen_off_time : 60
24/07/06 15:17:27,361 [DEBUG] rgb_enable : True
24/07/06 15:17:27,361 [DEBUG] rgb_style : breath
24/07/06 15:17:27,362 [DEBUG] rgb_color : 0a1aff
24/07/06 15:17:27,362 [DEBUG] rgb_blink_speed : 50
24/07/06 15:17:27,362 [DEBUG] rgb_pwm_freq : 1000
24/07/06 15:17:27,362 [DEBUG] rgb_pin : 10
24/07/06 15:17:27,365 [DEBUG] power_key_pin : 16
24/07/06 15:17:27,365 [DEBUG] fan_pin : 6
24/07/06 15:17:27,365 [DEBUG] update_frequency : 0.5
24/07/06 15:17:27,365 [DEBUG] temp_unit : C
24/07/06 15:17:27,365 [DEBUG] fan_temp : 50.0
24/07/06 15:17:27,365 [DEBUG] screen_always_on : False
24/07/06 15:17:27,365 [DEBUG] screen_off_time : 60
24/07/06 15:17:27,365 [DEBUG] rgb_enable : True
24/07/06 15:17:27,366 [DEBUG] rgb_style : breath
24/07/06 15:17:27,366 [DEBUG] rgb_color : 0a1aff
24/07/06 15:17:27,366 [DEBUG] rgb_blink_speed : 50
24/07/06 15:17:27,366 [DEBUG] rgb_pwm_freq : 1000
24/07/06 15:17:27,366 [DEBUG] rgb_pin : 10
24/07/06 15:17:27,373 [DEBUG] rgb_strip init success
24/07/06 15:17:27,379 [DEBUG] rgb_strip init success
24/07/06 15:17:27,379 [DEBUG] close_rgb in sys.argv
24/07/06 15:17:27,379 [DEBUG] rgb_strip clear
24/07/06 15:17:27,582 [DEBUG] oled init success
24/07/06 15:17:27,629 [DEBUG] rgb_show
24/07/06 15:17:27,630 [DEBUG] rgb_show: breath
24/07/06 15:17:27,694 [DEBUG] Get IP: 192.168.232.210
------------------------24/07/06 15:54:22------------------------
username:
username:
Kernel Version:
OS Version:
24/07/06 15:54:22,563 [DEBUG] power_key_pin : 16
24/07/06 15:54:22,563 [DEBUG] fan_pin : 6
24/07/06 15:54:22,564 [DEBUG] update_frequency : 0.5
24/07/06 15:54:22,564 [DEBUG] temp_unit : C
24/07/06 15:54:22,564 [DEBUG] fan_temp : 50.0
24/07/06 15:54:22,564 [DEBUG] screen_always_on : False
24/07/06 15:54:22,564 [DEBUG] screen_off_time : 60
24/07/06 15:54:22,564 [DEBUG] rgb_enable : True
24/07/06 15:54:22,564 [DEBUG] rgb_style : breath
24/07/06 15:54:22,564 [DEBUG] rgb_color : 0a1aff
24/07/06 15:54:22,565 [DEBUG] rgb_blink_speed : 50
24/07/06 15:54:22,565 [DEBUG] rgb_pwm_freq : 1000
PCB info:
24/07/06 15:54:22,565 [DEBUG] rgb_pin : 10
Revision : c03114
24/07/06 15:54:22,567 [DEBUG] power_key_pin : 16
24/07/06 15:54:22,567 [DEBUG] fan_pin : 6
24/07/06 15:54:22,568 [DEBUG] update_frequency : 0.5
24/07/06 15:54:22,568 [DEBUG] temp_unit : C
24/07/06 15:54:22,568 [DEBUG] fan_temp : 50.0
24/07/06 15:54:22,568 [DEBUG] screen_always_on : False
24/07/06 15:54:22,568 [DEBUG] screen_off_time : 60
24/07/06 15:54:22,568 [DEBUG] rgb_enable : True
24/07/06 15:54:22,568 [DEBUG] rgb_style : breath
24/07/06 15:54:22,569 [DEBUG] rgb_color : 0a1aff
24/07/06 15:54:22,569 [DEBUG] rgb_blink_speed : 50
24/07/06 15:54:22,569 [DEBUG] rgb_pwm_freq : 1000
24/07/06 15:54:22,569 [DEBUG] rgb_pin : 10
24/07/06 15:54:22,576 [DEBUG] rgb_strip init success
24/07/06 15:54:22,580 [DEBUG] rgb_strip init success
24/07/06 15:54:22,581 [DEBUG] close_rgb in sys.argv
24/07/06 15:54:22,581 [DEBUG] rgb_strip clear
24/07/06 15:54:22,786 [DEBUG] oled init success
24/07/06 15:54:22,823 [DEBUG] rgb_show
24/07/06 15:54:22,825 [DEBUG] rgb_show: breath
24/07/06 15:54:22,894 [DEBUG] Get IP: 192.168.232.210
------------------------24/07/06 18:49:42------------------------
username:
username:
Kernel Version:
OS Version:
OS Version:
PCB info:
Revision : c03114
24/07/06 18:49:42,529 [DEBUG] power_key_pin : 16
24/07/06 18:49:42,529 [DEBUG] fan_pin : 6
24/07/06 18:49:42,530 [DEBUG] update_frequency : 0.5
24/07/06 18:49:42,530 [DEBUG] temp_unit : C
24/07/06 18:49:42,530 [DEBUG] fan_temp : 50.0
24/07/06 18:49:42,530 [DEBUG] screen_always_on : False
24/07/06 18:49:42,530 [DEBUG] screen_off_time : 60
24/07/06 18:49:42,530 [DEBUG] rgb_enable : True
24/07/06 18:49:42,530 [DEBUG] rgb_style : breath
PCB info:
24/07/06 18:49:42,531 [DEBUG] rgb_color : 0a1aff
Revision : c03114
24/07/06 18:49:42,531 [DEBUG] rgb_blink_speed : 50
24/07/06 18:49:42,531 [DEBUG] rgb_pwm_freq : 1000
24/07/06 18:49:42,531 [DEBUG] rgb_pin : 10
24/07/06 18:49:42,535 [DEBUG] power_key_pin : 16
24/07/06 18:49:42,535 [DEBUG] fan_pin : 6
24/07/06 18:49:42,535 [DEBUG] update_frequency : 0.5
24/07/06 18:49:42,535 [DEBUG] temp_unit : C
24/07/06 18:49:42,535 [DEBUG] fan_temp : 50.0
24/07/06 18:49:42,536 [DEBUG] screen_always_on : False
24/07/06 18:49:42,536 [DEBUG] screen_off_time : 60
24/07/06 18:49:42,536 [DEBUG] rgb_enable : True
24/07/06 18:49:42,536 [DEBUG] rgb_style : breath
24/07/06 18:49:42,536 [DEBUG] rgb_color : 0a1aff
24/07/06 18:49:42,537 [DEBUG] rgb_blink_speed : 50
24/07/06 18:49:42,537 [DEBUG] rgb_pwm_freq : 1000
24/07/06 18:49:42,537 [DEBUG] rgb_pin : 10
24/07/06 18:49:42,542 [DEBUG] rgb_strip init success
24/07/06 18:49:42,542 [DEBUG] close_rgb in sys.argv
24/07/06 18:49:42,542 [DEBUG] rgb_strip clear
24/07/06 18:49:42,548 [DEBUG] rgb_strip init success
24/07/06 18:49:42,784 [DEBUG] oled init success
24/07/06 18:49:42,861 [DEBUG] rgb_show
24/07/06 18:49:42,862 [DEBUG] rgb_show: breath
24/07/06 18:49:42,940 [DEBUG] Get IP: 192.168.232.210
24/07/07 06:46:10,889 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
24/07/07 06:46:11,298 [DEBUG] error
24/07/07 06:46:11,298 [DEBUG] DigitalOutputDevice is closed or uninitialized
------------------------24/07/07 06:46:11------------------------
username: dad
Kernel Version:
username: dad
Kernel Version:
OS Version:
24/07/07 06:46:11,925 [DEBUG] power_key_pin : 16
24/07/07 06:46:11,926 [DEBUG] fan_pin : 6
24/07/07 06:46:11,926 [DEBUG] update_frequency : 0.5
24/07/07 06:46:11,926 [DEBUG] temp_unit : C
24/07/07 06:46:11,926 [DEBUG] fan_temp : 50.0
24/07/07 06:46:11,926 [DEBUG] screen_always_on : False
24/07/07 06:46:11,927 [DEBUG] screen_off_time : 60
24/07/07 06:46:11,927 [DEBUG] rgb_enable : True
24/07/07 06:46:11,927 [DEBUG] rgb_style : breath
24/07/07 06:46:11,927 [DEBUG] rgb_color : 0a1aff
24/07/07 06:46:11,927 [DEBUG] rgb_blink_speed : 50
24/07/07 06:46:11,927 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:46:11,927 [DEBUG] rgb_pin : 10
24/07/07 06:46:11,939 [DEBUG] rgb_strip init success
24/07/07 06:46:11,939 [DEBUG] close_rgb in sys.argv
24/07/07 06:46:11,939 [DEBUG] rgb_strip clear
OS Version:
24/07/07 06:46:12,165 [DEBUG] power_key_pin : 16
24/07/07 06:46:12,165 [DEBUG] fan_pin : 6
24/07/07 06:46:12,165 [DEBUG] update_frequency : 0.5
24/07/07 06:46:12,165 [DEBUG] temp_unit : C
24/07/07 06:46:12,166 [DEBUG] fan_temp : 50.0
24/07/07 06:46:12,166 [DEBUG] screen_always_on : False
24/07/07 06:46:12,166 [DEBUG] screen_off_time : 60
24/07/07 06:46:12,166 [DEBUG] rgb_enable : True
24/07/07 06:46:12,166 [DEBUG] rgb_style : breath
24/07/07 06:46:12,166 [DEBUG] rgb_color : 0a1aff
24/07/07 06:46:12,166 [DEBUG] rgb_blink_speed : 50
24/07/07 06:46:12,167 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:46:12,167 [DEBUG] rgb_pin : 10
24/07/07 06:46:12,178 [DEBUG] rgb_strip init success
24/07/07 06:46:12,248 [DEBUG] oled init success
24/07/07 06:46:12,260 [DEBUG] rgb_show
24/07/07 06:46:12,261 [DEBUG] rgb_show: breath
24/07/07 06:46:12,364 [DEBUG] Get IP: 192.168.232.210
24/07/07 06:48:42,107 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
24/07/07 06:48:42,451 [DEBUG] error
24/07/07 06:48:42,451 [DEBUG] DigitalOutputDevice is closed or uninitialized
------------------------24/07/07 06:48:42------------------------
username: dad
Kernel Version:
------------------------24/07/07 06:48:43------------------------
username: dad
Kernel Version:
24/07/07 06:48:43,166 [DEBUG] power_key_pin : 16
24/07/07 06:48:43,167 [DEBUG] fan_pin : 6
24/07/07 06:48:43,167 [DEBUG] update_frequency : 0.5
24/07/07 06:48:43,167 [DEBUG] temp_unit : C
24/07/07 06:48:43,167 [DEBUG] fan_temp : 50.0
24/07/07 06:48:43,167 [DEBUG] screen_always_on : True
24/07/07 06:48:43,167 [DEBUG] screen_off_time : 60
24/07/07 06:48:43,167 [DEBUG] rgb_enable : True
24/07/07 06:48:43,167 [DEBUG] rgb_style : breath
24/07/07 06:48:43,168 [DEBUG] rgb_color : 0a1aff
24/07/07 06:48:43,168 [DEBUG] rgb_blink_speed : 50
24/07/07 06:48:43,168 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:48:43,168 [DEBUG] rgb_pin : 10
24/07/07 06:48:43,182 [DEBUG] rgb_strip init success
24/07/07 06:48:43,183 [DEBUG] close_rgb in sys.argv
24/07/07 06:48:43,183 [DEBUG] rgb_strip clear
OS Version:
24/07/07 06:48:43,265 [DEBUG] power_key_pin : 16
24/07/07 06:48:43,266 [DEBUG] fan_pin : 6
24/07/07 06:48:43,268 [DEBUG] update_frequency : 0.5
24/07/07 06:48:43,269 [DEBUG] temp_unit : C
24/07/07 06:48:43,270 [DEBUG] fan_temp : 50.0
24/07/07 06:48:43,270 [DEBUG] screen_always_on : True
24/07/07 06:48:43,271 [DEBUG] screen_off_time : 60
24/07/07 06:48:43,271 [DEBUG] rgb_enable : True
24/07/07 06:48:43,272 [DEBUG] rgb_style : breath
24/07/07 06:48:43,273 [DEBUG] rgb_color : 0a1aff
24/07/07 06:48:43,274 [DEBUG] rgb_blink_speed : 50
24/07/07 06:48:43,274 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:48:43,275 [DEBUG] rgb_pin : 10
24/07/07 06:48:43,286 [DEBUG] rgb_strip init success
24/07/07 06:48:43,391 [DEBUG] oled init success
24/07/07 06:48:43,407 [DEBUG] rgb_show
24/07/07 06:48:43,408 [DEBUG] rgb_show: breath
24/07/07 06:48:43,472 [DEBUG] Get IP: 192.168.232.210
24/07/07 06:49:28,781 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
24/07/07 06:49:29,275 [DEBUG] error
24/07/07 06:49:29,275 [DEBUG] Button is closed or uninitialized
------------------------24/07/07 06:49:29------------------------
username: dad
Kernel Version:
username: dad
Kernel Version:
OS Version:
PCB info:
Revision : c03114
24/07/07 06:49:29,794 [DEBUG] power_key_pin : 16
24/07/07 06:49:29,794 [DEBUG] fan_pin : 6
24/07/07 06:49:29,794 [DEBUG] update_frequency : 0.5
24/07/07 06:49:29,794 [DEBUG] temp_unit : C
24/07/07 06:49:29,794 [DEBUG] fan_temp : 50.0
24/07/07 06:49:29,795 [DEBUG] screen_always_on : True
24/07/07 06:49:29,795 [DEBUG] screen_off_time : 60
24/07/07 06:49:29,795 [DEBUG] rgb_enable : True
24/07/07 06:49:29,795 [DEBUG] rgb_style : breath
24/07/07 06:49:29,795 [DEBUG] rgb_color : 0a1aff
24/07/07 06:49:29,795 [DEBUG] rgb_blink_speed : 50
24/07/07 06:49:29,795 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:49:29,795 [DEBUG] rgb_pin : 10
24/07/07 06:49:29,807 [DEBUG] rgb_strip init success
24/07/07 06:49:29,807 [DEBUG] close_rgb in sys.argv
24/07/07 06:49:29,808 [DEBUG] rgb_strip clear
PCB info:
Revision : c03114
24/07/07 06:49:30,027 [DEBUG] power_key_pin : 16
24/07/07 06:49:30,027 [DEBUG] fan_pin : 6
24/07/07 06:49:30,028 [DEBUG] update_frequency : 0.5
24/07/07 06:49:30,029 [DEBUG] temp_unit : C
24/07/07 06:49:30,029 [DEBUG] fan_temp : 50.0
24/07/07 06:49:30,030 [DEBUG] screen_always_on : True
24/07/07 06:49:30,030 [DEBUG] screen_off_time : 60
24/07/07 06:49:30,030 [DEBUG] rgb_enable : True
24/07/07 06:49:30,030 [DEBUG] rgb_style : breath
24/07/07 06:49:30,030 [DEBUG] rgb_color : 0a1aff
24/07/07 06:49:30,030 [DEBUG] rgb_blink_speed : 50
24/07/07 06:49:30,030 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:49:30,030 [DEBUG] rgb_pin : 10
24/07/07 06:49:30,041 [DEBUG] rgb_strip init success
24/07/07 06:49:30,093 [DEBUG] oled init success
24/07/07 06:49:30,105 [DEBUG] rgb_show
24/07/07 06:49:30,106 [DEBUG] rgb_show: breath
24/07/07 06:49:30,186 [DEBUG] Get IP: 192.168.232.210
24/07/07 06:54:42,665 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
24/07/07 06:54:43,236 [DEBUG] error
24/07/07 06:54:43,236 [DEBUG] Button is closed or uninitialized
------------------------24/07/07 06:54:43------------------------
username: dad
Kernel Version:
username: dad
Kernel Version:
OS Version:
24/07/07 06:54:43,693 [DEBUG] power_key_pin : 16
24/07/07 06:54:43,693 [DEBUG] fan_pin : 6
24/07/07 06:54:43,693 [DEBUG] update_frequency : 0.5
24/07/07 06:54:43,693 [DEBUG] temp_unit : C
24/07/07 06:54:43,694 [DEBUG] fan_temp : 60.0
24/07/07 06:54:43,694 [DEBUG] screen_always_on : True
24/07/07 06:54:43,694 [DEBUG] screen_off_time : 60
24/07/07 06:54:43,694 [DEBUG] rgb_enable : True
24/07/07 06:54:43,694 [DEBUG] rgb_style : breath
24/07/07 06:54:43,694 [DEBUG] rgb_color : 0a1aff
24/07/07 06:54:43,695 [DEBUG] rgb_blink_speed : 50
24/07/07 06:54:43,695 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:54:43,695 [DEBUG] rgb_pin : 10
24/07/07 06:54:43,706 [DEBUG] rgb_strip init success
24/07/07 06:54:43,706 [DEBUG] close_rgb in sys.argv
24/07/07 06:54:43,706 [DEBUG] rgb_strip clear
OS Version:
PCB info:
Revision : c03114
24/07/07 06:54:43,902 [DEBUG] power_key_pin : 16
24/07/07 06:54:43,902 [DEBUG] fan_pin : 6
24/07/07 06:54:43,902 [DEBUG] update_frequency : 0.5
24/07/07 06:54:43,902 [DEBUG] temp_unit : C
24/07/07 06:54:43,902 [DEBUG] fan_temp : 60.0
24/07/07 06:54:43,902 [DEBUG] screen_always_on : True
24/07/07 06:54:43,902 [DEBUG] screen_off_time : 60
24/07/07 06:54:43,902 [DEBUG] rgb_enable : True
24/07/07 06:54:43,903 [DEBUG] rgb_style : breath
24/07/07 06:54:43,903 [DEBUG] rgb_color : 0a1aff
24/07/07 06:54:43,903 [DEBUG] rgb_blink_speed : 50
24/07/07 06:54:43,903 [DEBUG] rgb_pwm_freq : 1000
24/07/07 06:54:43,903 [DEBUG] rgb_pin : 10
24/07/07 06:54:43,916 [DEBUG] rgb_strip init success
24/07/07 06:54:43,970 [DEBUG] oled init success
24/07/07 06:54:43,980 [DEBUG] rgb_show
24/07/07 06:54:43,981 [DEBUG] rgb_show: breath
24/07/07 06:54:44,056 [DEBUG] Get IP: 192.168.232.210
------------------------24/07/07 08:28:49------------------------
SNIP
------------------------24/07/07 08:40:14------------------------
username:
username:
Kernel Version:
OS Version:
OS Version:
PCB info:
Revision : c03114
24/07/07 08:40:15,182 [DEBUG] power_key_pin : 16
24/07/07 08:40:15,182 [DEBUG] fan_pin : 6
24/07/07 08:40:15,183 [DEBUG] update_frequency : 0.5
24/07/07 08:40:15,183 [DEBUG] temp_unit : C
24/07/07 08:40:15,183 [DEBUG] fan_temp : 60.0
24/07/07 08:40:15,184 [DEBUG] screen_always_on : True
24/07/07 08:40:15,184 [DEBUG] screen_off_time : 60
24/07/07 08:40:15,184 [DEBUG] rgb_enable : True
24/07/07 08:40:15,184 [DEBUG] rgb_style : breath
24/07/07 08:40:15,184 [DEBUG] rgb_color : 0a1aff
24/07/07 08:40:15,185 [DEBUG] rgb_blink_speed : 50
24/07/07 08:40:15,185 [DEBUG] rgb_pwm_freq : 1000
24/07/07 08:40:15,185 [DEBUG] rgb_pin : 10
PCB info:
Revision : c03114
24/07/07 08:40:15,190 [DEBUG] power_key_pin : 16
24/07/07 08:40:15,190 [DEBUG] fan_pin : 6
24/07/07 08:40:15,191 [DEBUG] update_frequency : 0.5
24/07/07 08:40:15,191 [DEBUG] temp_unit : C
24/07/07 08:40:15,191 [DEBUG] fan_temp : 60.0
24/07/07 08:40:15,191 [DEBUG] screen_always_on : True
24/07/07 08:40:15,191 [DEBUG] screen_off_time : 60
24/07/07 08:40:15,191 [DEBUG] rgb_enable : True
24/07/07 08:40:15,192 [DEBUG] rgb_style : breath
24/07/07 08:40:15,192 [DEBUG] rgb_color : 0a1aff
24/07/07 08:40:15,192 [DEBUG] rgb_blink_speed : 50
24/07/07 08:40:15,192 [DEBUG] rgb_pwm_freq : 1000
24/07/07 08:40:15,192 [DEBUG] rgb_pin : 10
24/07/07 08:40:15,197 [DEBUG] rgb_strip init success
24/07/07 08:40:15,197 [DEBUG] close_rgb in sys.argv
24/07/07 08:40:15,197 [DEBUG] rgb_strip clear
24/07/07 08:40:15,203 [DEBUG] rgb_strip init success
24/07/07 08:40:15,439 [DEBUG] oled init success
24/07/07 08:40:15,519 [DEBUG] rgb_show
24/07/07 08:40:15,520 [DEBUG] rgb_show: breath
24/07/07 08:40:15,592 [DEBUG] Get IP: 192.168.232.210
------------------------24/07/07 18:54:57------------------------
username:
username:
Kernel Version:
OS Version:
24/07/07 18:54:58,101 [DEBUG] power_key_pin : 16
24/07/07 18:54:58,101 [DEBUG] fan_pin : 6
24/07/07 18:54:58,101 [DEBUG] update_frequency : 0.5
24/07/07 18:54:58,101 [DEBUG] temp_unit : C
24/07/07 18:54:58,102 [DEBUG] update_frequency : 0.5
24/07/07 18:54:58,102 [DEBUG] fan_temp : 60.0
24/07/07 18:54:58,102 [DEBUG] temp_unit : C
24/07/07 18:54:58,102 [DEBUG] screen_always_on : True
24/07/07 18:54:58,102 [DEBUG] screen_off_time : 60
24/07/07 18:54:58,102 [DEBUG] rgb_enable : True
24/07/07 18:54:58,102 [DEBUG] rgb_style : breath
24/07/07 18:54:58,103 [DEBUG] rgb_style : breath
24/07/07 18:54:58,103 [DEBUG] rgb_color : 0a1aff
24/07/07 18:54:58,103 [DEBUG] rgb_blink_speed : 50
24/07/07 18:54:58,103 [DEBUG] rgb_pwm_freq : 1000
24/07/07 18:54:58,103 [DEBUG] rgb_pin : 10
24/07/07 18:54:58,114 [DEBUG] rgb_strip init success
24/07/07 18:54:58,114 [DEBUG] close_rgb in sys.argv
24/07/07 18:54:58,115 [DEBUG] rgb_strip clear
24/07/07 18:54:58,286 [DEBUG] oled init success
24/07/07 18:54:58,367 [DEBUG] rgb_show
24/07/07 18:54:58,367 [DEBUG] rgb_show: breath
24/07/07 18:54:58,462 [DEBUG] Get IP: 192.168.232.210
