I just recieved my pironman case, and assembled it.
All is OK except RGB is white and always on, no matter witch config i place with pironman commands.
the fan is OK, OLED to and power button work.
I double checked cables, jumpers.
I reinstalled from scrtach with the latest OS and clone the project with the same result
Now, i need help
here is a screen copy
sudo python3 /opt/pironman/main.py
------------------------23/03/21 18:01:12------------------------
pironman version: 1.3.0
username: pi
config_file: /home/pi/.config/pironman/config.txt
Kernel Version:
Linux raspi4 6.1.19-v8+ #1637 SMP PREEMPT Tue Mar 14 11:11:47 GMT 2023 aarch64 GNU/Linux
OS Version:
No LSB modules are available.
Description:	Raspbian GNU/Linux 11 (bullseye)
PCB info:
Revision	: b03111
Model		: Raspberry Pi 4 Model B Rev 1.1
23/03/21 18:01:12,894 [DEBUG] power_key_pin : 16
23/03/21 18:01:12,895 [DEBUG] fan_pin : 6
23/03/21 18:01:12,895 [DEBUG] rgb_pin : 12
23/03/21 18:01:12,895 [DEBUG] update_frequency : 0.5
23/03/21 18:01:12,895 [DEBUG] temp_unit : C
23/03/21 18:01:12,895 [DEBUG] fan_temp : 50.0
23/03/21 18:01:12,896 [DEBUG] screen_always_on : True
23/03/21 18:01:12,896 [DEBUG] screen_off_time : 60
23/03/21 18:01:12,896 [DEBUG] rgb_switch: True
23/03/21 18:01:12,896 [DEBUG] rgb_blink_speed : 50
23/03/21 18:01:12,896 [DEBUG] rgb_color : 00ff00
23/03/21 18:01:12,897 [DEBUG]
