I’m working on a project I want to use the Pironman5 case for, but I will need at least 4 HATs. That many HATs will need to be attached firmly to the side, so I plan to replace the side acrylic sheet with an aluminum bracket with standoffs on it, then make extensions for the top, bottom, front, and back, then use the original side on the outside of all my HATs.
I’m hoping a 3D Model of the Pironman5 case is available, that would save me a lot of measuring and tedious trial and error to get everything to fit properly. I us Rhino, so a Rhino .3DM file would be best, but I can import many other formats as well.
If solid model isn’t available, then I could use CAD files as well. Rhino can import just about anything.
Any help with this is greatly appreciated!
