Hi guys I just got a pironman5 but when i try to call the git to install the software it sends me a bus error
Did you copy\paste commands from instructions? Which OS are you using?
Yes I tried several times and fresh installs, using latest raspios. Keeps getting bus error when trying to run the code.
Can you take a print screen of the issue?
Thank you for your replies, seems rp imager is stil an issue. Used custom rom and ran the code after and it worked.
