I got the Pironman 5 Kit yesterday and has some issues with setting it up. Initially I was getting buffer i/o errors and it turned out to be the SD extender board. I am being sent a V14 board to replace the V12 I got in the kit. OLED didnt work initially but re-installing and rebooting the pironman software fixed the issue.
After setting up the eeprom and setting the values to 1 as noted in the guide, the rear case fans are always on at full blast. When I shutdown they turn off momentarily but then spin back up. I re-installed the Pironman5 module with no luck. No amount of re-installing and update fixes the issue. I read in another post to downgrade the kernal and reinstall but no luck (sudo rpi-update 44a287fe97c04506841fe3b3e794c70a2e01c7de). Also, in the Dashboard there is no section/option to see or control the fans.
I am using the most recent PiOS image with my Pi5 8gb. I’m new-ish to the community so I’m kind of running these commands blindly as I’m finding them in the official guide and forums.
