Hello i’ve recetly bought the Pironman5 case
I’ve install the last PiOS , bookworm 64bit(2024-11-19) with the rasberry pi imager on a nvme 2T crucial P3plus
But after “the welcome to the raspberry pi desktop” screen , there is a black with busybox…
On this screen i can write with my keyboard
I’ve try to install the os on a microsd and it works well
I’ve tried to install batoceralinux on the nvme but it failed too on a screen “resize error” but i can’t use the kb to go further
When i connect the nvme to my computer I can see the 2 part of the batocera disk
I don’t know what to do to use the nvme
On the video I have install on the nvme on windows then install the nvme on pironman5
it won’t work
After I’ve install the os on sd card and use the copy os from micro sd to nvme and it works well
I’ve tried also the batocera install on nvme with rapsberryimager on a windows computer then install the nvme on the pironman5 but it also failed to created partition
On Windows you can also try to write images with https://etcher.balena.io/
If it’s not working and if you have many SD card and SD card usb adapter. Run raspiOS on main SD card. From raspiOS install batocera into another SD card. Then shutdown Pironman5, remove raspiOS SD, put and boot with batocera, update it. Then shut it down, reboot with raspiOS, put batocera in SD card reader and copy it on nvme with UUID selected and now try to boot from nvme.
