Rgb Case fans - Pironman5
I’ve not been able to find anything on here or else where on Google. Is the RGB on the case fans controllable. I’ve managed to get the fans to power on when needed turn off once no longer required however I can’t seem to find away to control the RGB to match the rest of the system. Also when I turn off the RGB on the board, the fans keep displaying rgb.
Other than that its great little kit.
Thanks in advance.
Unfortunately, You can’t control RGB rear fan colors. They have random color. If you want specific color you can try to search it on Amazon as 4010 5v cooling Fan blue. Or maybe 4010 5v PWM RGB fan, I’m just not sure where to plug signal wire to rpi\pironman5 board to match with RGB LEDs on board, and set the software. Hope this gonna help you.
Thanks for the reply, I thought that might have been the case since there was only 2 wires per fan. I’ll just go ahead and keep them turned off until they are needed for the time being.
Came here to ask this same question, super disappointing that the rear case fan LEDs are not controllable, they are obnoxiously bright…I’ve opted to just turn them off as well until they are needed at really high temps. Has anyone been able to find fans to replace these that are controllable to set the fan LED colors to match the case LED colors? @SunFounder_Moderator Any comment on this or suggestions? Thanks
