Hello, I’m trying to program our new arduino Sloth robot but running into an error when I try to program it. Here is the error message:
Sketch uses 3492 bytes (11%) of program storage space. Maximum is 30720 bytes.
Global variables use 259 bytes (12%) of dynamic memory, leaving 1789 bytes for local variables. Maximum is 2048 bytes.
“C:\Users\dan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude” “-CC:\Users\dan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf” -v -V -patmega328p -carduino “-PCOM12” -b115200 -D “-Uflash:w:C:\Users\dan\AppData\Local\Temp\arduino\sketches\D0D58934BE4355A5366E37E922A44D13/Test_robot.ino.hex:i”
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\dan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM12
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can’t open device “\.\COM12”: A device which does not exist was specified.
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
