In the instructions, Step 3 a red arrow indicated the connector uses a hinged clamp. However, in Step 5 there are no indicators indicating that the connector clap uses an in/out type clamp. I got confused and could not open the connector until, by luck, I pulled on the connector.
I would add a red arrow pointing up above the connector to indicate that the clamp is not hinged and pulls out. Otherwise very clear instructions.
Thank you very much for the suggestions you provided. We will take them into comprehensive consideration.
If you have any doubts about the assembly, you can contact us at any time and we will be happy to answer your questions.
Additionally, our tutorials include related assembly videos, so you can also follow the step-by-step instructions in the videos to assemble the Pironman.2. Component List and Assembly Instructions — SunFounder Pironman documentation
