Wheels won't turn
My new Raspberry Pi-Car Steering was working well until it had stopped working. When I use my Raspberry Pi on the Keyboard control, it doesn’t work, and when I try to calibrate it, it makes some noise, moves directly to the right, but still doesn’t move at all. Here is an image of what state it is always in.
It looks like there might be an issue with the steering servo.
When you say the keyboard cannot control it, do you mean only the steering servo is unresponsive, or are all components unresponsive?
Please try swapping the steering servo with one of the other two servos (i.e., exchange their pins) and see if the steering servo works properly after the swap.
I mean thar only the steering servo is unresponsive.
It is likely that the steering servo is faulty.We will arrange a replacement for you.Please contact service@sunfounder.com to provide your address and original order number if possible.
