Which operating system to install for PiSloth?
Hello there!
I got a PiSloth and in the instruction it says “choose Raspberry Pi Other” and the “Raspberry Pi OS (Legacy)”, but when I clicked into “Other”, there are so many options, should I pick “Legacy 32-bit” or 64 bit? And should I do Full, Lite or just regular?
Thank you! I appreciate your help!
Warmest regards,
Yiyi
The legacy versions, both 32-bit and 64-bit, are compatible.
Recommend using a system with a desktop environment.
Thank you very much! Yes, I used the 64-bit and it worked perfectly!
