Wifi Module not responsive Pico4WD Car
I have pico 4 wd kit, after a lot of troubleshooting I found onboard wifi module is not responding. I ordered ESP-01 module online but could provide instructions on how to bypass onboard wifi module and add this new chip into RDP ?
kit url -
https://docs.sunfounder.com/projects/pico-4wd-car/en/latest/
Which version of the pico-4wd product are you currently using? Suggest providing a picture of the product for us to see.
Your new ESP-01 module connects to RDP normally, go back and re-upload the code and see how it works.
This is ESP pinout … how to connect this to RDP and by-pass onboard wifi chip ?
You are currently using an older version of the product. The RDP expansion board is equipped with a Wi-Fi module, and if the Wi-Fi module is damaged, you will need to replace the entire RDP expansion board.
We recommend that you provide us with a picture of the RDP expansion board so we can confirm whether it is the older version.
