If the rpi is overclocked, will it be problematic for the ws2812 data timing needed for the rgb?
If you have a good power supply it’s supposed to work.
You missed the point of the question…if the ws2812 data timing is based on the processor speed, the LEDS won’t work if the processor speed is changed, because the data stream timing is VERY critical…
I overclocked my pironman v2 and ws2812 work perfectly.
Thank you. I’ll give it a try.
