Ws2812 strip not working
I’ve copied the circuit as it is listed here 3.3 RGB LED Strip — SunFounder Kepler Kit for Raspberry Pi Pico W 1.0 documentation
And I have made sure to include the ws2812.py library in the pico.
This is a brand new kepler kit I purchased and I’m not sure why it’s not working.
What are some ways I can troubleshoot?
1、Please make sure the wiring is correct. (Is the wiring firm, is the PICO W in good contact with the breadboard, is the RGB in good contact with the breadboard)
2、Is MicroPython installed correctly on your Pico W, please refer to the tutorial:
https://docs.sunfounder.com/projects/kepler-kit/en/latest/pyproject/python_start/install_micropython_to_pico.html
3、Is the source code downloaded correctly.
4、Is the executed code correct.
5、ws2812.py library is uploaded in PICO W or not.
6、Is it possible to run other module functions.
If the above confirms no problem, it may be that the RGB is damaged, we will send you a replacement module accordingly.
Thank you for your reply. My problem was that the pi (again) wasn’t securely placed in the breadboard
