4TB+ NVMe Drives & Rasperry Pi OS (Bookworm)
Since the community guidelines state I can’t post actual LINKS to other sites, I’m limited in what I can say here… but if you’re new to the Rasberry Pi market, interested in purchasing the Raspberry Pi 5, and LOVE the Pironman 5 setup as I do, but you’re curious about the size limitations of the NVMe drive you can install AND BOOT from the Raspberry Pi Bookworm (x64) OS… You can Google “raspberrypi 4TB 8TB” and you should see a result for a raspberrypi.com forum. There you will see a post by one Patrick Wallner, AKA: “mcpatric”. I’m a n00b, but was able to follow his instructions and install Bookworm x64 on a Pi 5 with a 4TB Samsung 980 Pro w/o too many problems (I had to boot from a USB OS instead of the microSD which the instructions said though, that’s the only difference). Cheers and props to Sunfounder and Mr. Wallner!
