AI Fusion Lab Batteries
AI Fusion Kit Batteries
Documentation says to fully charge the batteries before connecting them to module. How are you supposed to do that? Do you connect the batteries to the board. Connect the PSU and let the batteries charge and then turn the Fusion board on? Or, do you need a separate charger for the battery pack?
First, connect the battery to the main board, then connect the power supply to charge the battery. Finally, turn on the Fusion board.
(Actually, you can use it even if it’s not fully charged — but charging it fully before first use will help reduce battery wear over time.)
