Camera esp32 zeus car
Salut,
I can’t get the esp32 cam camera to work. I updated the firmware, upload the code, try in sta and ap mode. Tried in ai, without ai, face detection or pose. Nothing to do. On the application I have a question mark.
Do you have an idea?
Thank you for your help
It’s highly likely that the lens of your ESP32-CAM module is not properly installed or secured, which is preventing the camera image from being recognized.
Please follow the video we provided to verify that the camera is correctly installed and fixed in place.
We suggest re-seating the lens (unplugging and replugging it) and then reconnecting to the APP to see if the display returns to normal.
Thank you very much for your reply, but nothing has worked; the camera still isn’t functioning despite all the checks. For your information, I have projects using ESP32 cameras (Home Assistant) that work without any problems.
Do you think the board could be faulty? I see that it is not the same camera as on your video (OV2640). Can a track?
Videos
The problem isn’t with the lens because I tried it on another card. I think the card is faulty. How do I flash a blank ESP32 cam card with the camera’s software?
You will need a programmer (burner) to flash the firmware onto your own ESP32 module.
If you have confirmed that the lens is not the issue, we can arrange to send you a new ESP32 module to see if that resolves the problem.
Good morning,
Very well, we can do that, I am sure and certain that the lens works very well, it is even of better quality than the one I have on my other ESP32 cam projects.
Will the ESP32 cam you send me already be flashed?
How do you want to proceed?
Thank you for your help in any case.
Have a good day
Correct. The replacement ESP32-CAM module we will arrange to send to you has already been pre-programmed with the firmware.
Please contact service@sunfounder.com and provide your shipping address.
Hello
Well received the new esp32-cam and it works fine.
