DAC HAT blocks boot
I am currently running Volumio OS on the Pi5 8GB housed in the Pironman5 chasis with M2.NVMe board connected with PCIe. NVMe module is KIOXIA 1TB.
When I boot Pi5 in Pironman from NVMe, it boots normally and Volumio service works with no issue. After I istall Inno-Maker RPI-DAC-Pro on GPIO, Pi5 does not boot. Even when I suppy power to DAC separately, Pi5 does not boot.
Is there anyone who experienced the same issue and found some way that make the system+DAC works?
I am not sure if I need extra driver or some modification of configuration.
Is there any recommended DAC hat that works with Pironman+Pi5+NVMe?
We are very sorry, we haven’t tested Inno-Maker RPI-DAC-Pro with pironman5 compatibility issue and can’t give you professional advice.
