Dashboard will not launch after apt update
I have PiRonman 5 MAX running for some time and after an apt update and upgrade I can no longer open site :34001. I have a Raspberry Pi 5 running Raspberry Pi OS (Legacy, 64-bit) port of Bookworm 2026-06-18.
Any suggestions?
Bill
Please try reinstalling the Pironman 5 software. It is possible that the apt update process overwrote some configuration settings.
You can reinstall the software by following the instructions in the link below:
:link: Setting Up on Raspberry Pi OS/Ubuntu/Kali Linux/Homebridge — SunFounder Pironman 5 documentation
I reinstalled the software per the link and still did not work.
So I built a new MicroSD Card with Raspberry Pi OS (Legacy, 64-bit) port of Bookworm 2026-06-18. Installed and powered up the Pironman 5 Raspberry Pi 5. SSH into it and the sudo apt update and upgrade and reboot. Unable to set the shutdown behavior through sudo raspi-config since option not available with this release. Then installed Pironman 5 selected 2 for Pironman 5 Max. Install was good and reboot. Then still unable to connect to port 34001. None of the Pironman 5 LEDs are on! I tried to view the back configuration …
sudo pironman5 -c
“system”: {}
I tried a restart … sudo systemctl restart pironman5.service
No change!
I repeated installed Pironman 5 selected 2 for Pironman 5 Max. After reboot no change.
We were unable to reproduce your issue on our side today – reinstalling pironman5 on a fresh system worked without any problems.
We will continue testing next week. In the meantime, could you please send us the output of the following command? This may help us locate the issue:
cat /var/log/pironman5/pironman5.log
Alternatively, you could try reinstalling the Raspberry Pi OS (Trixie 64‑bit) and then reinstalling pironman5 – this might resolve the problem.
Yesterday I did build a Raspberry PI OS Lite (64-bit) A port of Debian Trixie with no desktop environment 2026-06-18 and so far it is running without any issues.
Below is cat /var/log/pironman5/pironman5.log from the Bookworm build that was not working. Sorry for pasting it, I am not able to attach a doc to this thread.
Thanks for the help
Bill
26/07/29 16:20:16.823 [INFO]
26/07/29 16:20:16.823 [INFO] ############################################################
26/07/29 16:20:16.823 [INFO] Pironman5 Start
26/07/29 16:20:16.823 [INFO] Pironman5 version: 1.3.18
26/07/29 16:20:16.823 [INFO] Variant: Pironman 5 Max V2
26/07/29 16:20:16.823 [INFO] Config:
26/07/29 16:20:16.823 [INFO] {
26/07/29 16:20:16.823 [INFO] “system”: {
26/07/29 16:20:16.823 [INFO] “data_interval”: 1,
26/07/29 16:20:16.823 [INFO] “database_retention_days”: 30,
26/07/29 16:20:16.823 [INFO] “temperature_unit”: “C”,
26/07/29 16:20:16.823 [INFO] “enable_history”: true,
26/07/29 16:20:16.823 [INFO] “oled_enable”: true,
26/07/29 16:20:16.824 [INFO] “oled_rotation”: 0,
26/07/29 16:20:16.824 [INFO] “oled_sleep_timeout”: 10,
26/07/29 16:20:16.824 [INFO] “oled_pages”: [“mix”, “performance”, “ips”, “disk”],
26/07/29 16:20:16.824 [INFO] “rgb_enable”: true,
26/07/29 16:20:16.824 [INFO] “rgb_color”: “#0a1aff”,
26/07/29 16:20:16.824 [INFO] “rgb_brightness”: 100,
26/07/29 16:20:16.824 [INFO] “rgb_style”: “breathing”,
26/07/29 16:20:16.824 [INFO] “rgb_speed”: 50,
26/07/29 16:20:16.824 [INFO] “rgb_led_count”: 4,
26/07/29 16:20:16.824 [INFO] “rgb_led_count_min”: 4,
26/07/29 16:20:16.824 [INFO] “gpio_fan_pin”: 6,
26/07/29 16:20:16.824 [INFO] “gpio_fan_mode”: 0,
26/07/29 16:20:16.824 [INFO] “gpio_fan_led”: “follow”,
26/07/29 16:20:16.824 [INFO] “gpio_fan_led_pin”: 5,
26/07/29 16:20:16.824 [INFO] “debug_level”: “INFO”
26/07/29 16:20:16.824 [INFO] }
26/07/29 16:20:16.824 [INFO] Device info:
26/07/29 16:20:16.824 [INFO] {
26/07/29 16:20:16.824 [INFO] “name”: “Pironman 5 Max”,
26/07/29 16:20:16.824 [INFO] “id”: “pironman5-max”,
26/07/29 16:20:16.824 [INFO] “peripherals”: [
26/07/29 16:20:16.824 [INFO] “reboot”,
26/07/29 16:20:16.824 [INFO] “gpu_temperature”,
26/07/29 16:20:16.824 [INFO] “oled_page_disk”,
26/07/29 16:20:16.824 [INFO] “delete_log_file”,
26/07/29 16:20:16.825 [INFO] “ws2812”,
26/07/29 16:20:16.825 [INFO] “ip_address”,
26/07/29 16:20:16.825 [INFO] “oled_page_mix”,
26/07/29 16:20:16.825 [INFO] “pwm_fan_speed”,
26/07/29 16:20:16.825 [INFO] “oled_page_performance”,
26/07/29 16:20:16.825 [INFO] “cpu_temperature”,
26/07/29 16:20:16.825 [INFO] “oled_sleep”,
26/07/29 16:20:16.825 [INFO] “gpio_fan_mode”,
26/07/29 16:20:16.825 [INFO] “memory”,
26/07/29 16:20:16.825 [INFO] “pi5_power_button”,
26/07/29 16:20:16.825 [INFO] “oled”,
26/07/29 16:20:16.825 [INFO] “restart_service”,
26/07/29 16:20:16.825 [INFO] “mac_address”,
26/07/29 16:20:16.825 [INFO] “gpio_fan_led”,
26/07/29 16:20:16.825 [INFO] “oled_page_ips”,
26/07/29 16:20:16.825 [INFO] “log”,
26/07/29 16:20:16.825 [INFO] “debug_level”,
26/07/29 16:20:16.825 [INFO] “temperature_unit”,
26/07/29 16:20:16.825 [INFO] “clear_history”,
26/07/29 16:20:16.825 [INFO] “cpu”,
26/07/29 16:20:16.825 [INFO] “history”,
26/07/29 16:20:16.825 [INFO] “network”,
26/07/29 16:20:16.825 [INFO] “storage”,
26/07/29 16:20:16.825 [INFO] “gpio_fan_state”,
26/07/29 16:20:16.825 [INFO] “shutdown”
26/07/29 16:20:16.825 [INFO] ],
26/07/29 16:20:16.825 [INFO] “version”: “1.3.18”,
26/07/29 16:20:16.825 [INFO] “app_name”: “pironman5”,
26/07/29 16:20:16.825 [INFO] “config_path”: “/opt/pironman5/config.json”
26/07/29 16:20:16.825 [INFO] }
26/07/29 16:20:16.826 [INFO] PM_Auto version: 2.0.5
26/07/29 16:20:16.826 [INFO] PM_Dashboard version: 2.0.3
26/07/29 16:27:10.787 [INFO]
26/07/29 16:27:10.788 [INFO] ############################################################
26/07/29 16:27:10.788 [INFO] Pironman5 Start
26/07/29 16:27:10.788 [INFO] Pironman5 version: 1.3.18
26/07/29 16:27:10.788 [INFO] Variant: Pironman 5 Max V2
26/07/29 16:27:10.788 [INFO] Config:
26/07/29 16:27:10.788 [INFO] {
26/07/29 16:27:10.788 [INFO] “system”: {
26/07/29 16:27:10.788 [INFO] “data_interval”: 1,
26/07/29 16:27:10.788 [INFO] “database_retention_days”: 30,
26/07/29 16:27:10.788 [INFO] “temperature_unit”: “C”,
26/07/29 16:27:10.788 [INFO] “enable_history”: true,
26/07/29 16:27:10.788 [INFO] “oled_enable”: true,
26/07/29 16:27:10.789 [INFO] “oled_rotation”: 0,
26/07/29 16:27:10.789 [INFO] “oled_sleep_timeout”: 10,
26/07/29 16:27:10.789 [INFO] “oled_pages”: [“mix”, “performance”, “ips”, “disk”],
26/07/29 16:27:10.789 [INFO] “rgb_enable”: true,
26/07/29 16:27:10.789 [INFO] “rgb_color”: “#0a1aff”,
26/07/29 16:27:10.789 [INFO] “rgb_brightness”: 100,
26/07/29 16:27:10.789 [INFO] “rgb_style”: “breathing”,
26/07/29 16:27:10.789 [INFO] “rgb_speed”: 50,
26/07/29 16:27:10.789 [INFO] “rgb_led_count”: 4,
26/07/29 16:27:10.789 [INFO] “rgb_led_count_min”: 4,
26/07/29 16:27:10.789 [INFO] “gpio_fan_pin”: 6,
26/07/29 16:27:10.789 [INFO] “gpio_fan_mode”: 0,
26/07/29 16:27:10.789 [INFO] “gpio_fan_led”: “follow”,
26/07/29 16:27:10.789 [INFO] “gpio_fan_led_pin”: 5,
26/07/29 16:27:10.789 [INFO] “debug_level”: “INFO”
26/07/29 16:27:10.789 [INFO] }
26/07/29 16:27:10.789 [INFO] Device info:
26/07/29 16:27:10.789 [INFO] {
26/07/29 16:27:10.789 [INFO] “name”: “Pironman 5 Max”,
26/07/29 16:27:10.789 [INFO] “id”: “pironman5-max”,
26/07/29 16:27:10.789 [INFO] “peripherals”: [
26/07/29 16:27:10.789 [INFO] “temperature_unit”,
26/07/29 16:27:10.789 [INFO] “gpio_fan_mode”,
26/07/29 16:27:10.789 [INFO] “shutdown”,
26/07/29 16:27:10.789 [INFO] “ws2812”,
26/07/29 16:27:10.790 [INFO] “cpu”,
26/07/29 16:27:10.790 [INFO] “log”,
26/07/29 16:27:10.790 [INFO] “restart_service”,
26/07/29 16:27:10.790 [INFO] “reboot”,
26/07/29 16:27:10.790 [INFO] “oled”,
26/07/29 16:27:10.790 [INFO] “oled_sleep”,
26/07/29 16:27:10.790 [INFO] “gpu_temperature”,
26/07/29 16:27:10.790 [INFO] “history”,
26/07/29 16:27:10.790 [INFO] “storage”,
26/07/29 16:27:10.790 [INFO] “oled_page_mix”,
26/07/29 16:27:10.790 [INFO] “cpu_temperature”,
26/07/29 16:27:10.790 [INFO] “oled_page_performance”,
26/07/29 16:27:10.790 [INFO] “pwm_fan_speed”,
26/07/29 16:27:10.790 [INFO] “delete_log_file”,
26/07/29 16:27:10.790 [INFO] “debug_level”,
26/07/29 16:27:10.790 [INFO] “oled_page_disk”,
26/07/29 16:27:10.790 [INFO] “pi5_power_button”,
26/07/29 16:27:10.790 [INFO] “memory”,
26/07/29 16:27:10.790 [INFO] “mac_address”,
26/07/29 16:27:10.790 [INFO] “oled_page_ips”,
26/07/29 16:27:10.790 [INFO] “gpio_fan_led”,
26/07/29 16:27:10.790 [INFO] “clear_history”,
26/07/29 16:27:10.790 [INFO] “network”,
26/07/29 16:27:10.790 [INFO] “ip_address”,
26/07/29 16:27:10.790 [INFO] “gpio_fan_state”
26/07/29 16:27:10.790 [INFO] ],
26/07/29 16:27:10.790 [INFO] “version”: “1.3.18”,
26/07/29 16:27:10.790 [INFO] “app_name”: “pironman5”,
26/07/29 16:27:10.790 [INFO] “config_path”: “/opt/pironman5/config.json”
26/07/29 16:27:10.790 [INFO] }
26/07/29 16:27:10.791 [INFO] PM_Auto version: 2.0.5
26/07/29 16:27:10.791 [INFO] PM_Dashboard version: 2.0.3
26/07/29 16:32:14.597 [INFO]
26/07/29 16:32:14.598 [INFO] ############################################################
26/07/29 16:32:14.598 [INFO] Pironman5 Start
26/07/29 16:32:14.598 [INFO] Pironman5 version: 1.3.18
26/07/29 16:32:14.598 [INFO] Variant: Pironman 5 Max V2
26/07/29 16:32:14.598 [INFO] Config:
26/07/29 16:32:14.598 [INFO] {
26/07/29 16:32:14.598 [INFO] “system”: {
26/07/29 16:32:14.598 [INFO] “data_interval”: 1,
26/07/29 16:32:14.598 [INFO] “database_retention_days”: 30,
26/07/29 16:32:14.598 [INFO] “temperature_unit”: “C”,
26/07/29 16:32:14.598 [INFO] “enable_history”: true,
26/07/29 16:32:14.599 [INFO] “oled_enable”: true,
26/07/29 16:32:14.599 [INFO] “oled_rotation”: 0,
26/07/29 16:32:14.599 [INFO] “oled_sleep_timeout”: 10,
26/07/29 16:32:14.599 [INFO] “oled_pages”: [“mix”, “performance”, “ips”, “disk”],
26/07/29 16:32:14.599 [INFO] “rgb_enable”: true,
26/07/29 16:32:14.599 [INFO] “rgb_color”: “#0a1aff”,
26/07/29 16:32:14.599 [INFO] “rgb_brightness”: 100,
26/07/29 16:32:14.599 [INFO] “rgb_style”: “breathing”,
26/07/29 16:32:14.599 [INFO] “rgb_speed”: 50,
26/07/29 16:32:14.599 [INFO] “rgb_led_count”: 4,
26/07/29 16:32:14.599 [INFO] “rgb_led_count_min”: 4,
26/07/29 16:32:14.599 [INFO] “gpio_fan_pin”: 6,
26/07/29 16:32:14.599 [INFO] “gpio_fan_mode”: 0,
26/07/29 16:32:14.599 [INFO] “gpio_fan_led”: “follow”,
26/07/29 16:32:14.599 [INFO] “gpio_fan_led_pin”: 5,
26/07/29 16:32:14.599 [INFO] “debug_level”: “INFO”
26/07/29 16:32:14.599 [INFO] }
26/07/29 16:32:14.599 [INFO] Device info:
26/07/29 16:32:14.599 [INFO] {
26/07/29 16:32:14.599 [INFO] “name”: “Pironman 5 Max”,
26/07/29 16:32:14.599 [INFO] “id”: “pironman5-max”,
26/07/29 16:32:14.599 [INFO] “peripherals”: [
26/07/29 16:32:14.599 [INFO] “mac_address”,
26/07/29 16:32:14.600 [INFO] “ip_address”,
26/07/29 16:32:14.600 [INFO] “cpu”,
26/07/29 16:32:14.600 [INFO] “gpio_fan_led”,
26/07/29 16:32:14.600 [INFO] “pwm_fan_speed”,
26/07/29 16:32:14.600 [INFO] “temperature_unit”,
26/07/29 16:32:14.600 [INFO] “pi5_power_button”,
26/07/29 16:32:14.600 [INFO] “oled_page_ips”,
26/07/29 16:32:14.600 [INFO] “gpu_temperature”,
26/07/29 16:32:14.600 [INFO] “debug_level”,
26/07/29 16:32:14.600 [INFO] “history”,
26/07/29 16:32:14.600 [INFO] “oled”,
26/07/29 16:32:14.600 [INFO] “network”,
26/07/29 16:32:14.600 [INFO] “delete_log_file”,
26/07/29 16:32:14.600 [INFO] “oled_page_mix”,
26/07/29 16:32:14.600 [INFO] “log”,
26/07/29 16:32:14.600 [INFO] “storage”,
26/07/29 16:32:14.600 [INFO] “oled_page_performance”,
26/07/29 16:32:14.600 [INFO] “clear_history”,
26/07/29 16:32:14.600 [INFO] “restart_service”,
26/07/29 16:32:14.600 [INFO] “reboot”,
26/07/29 16:32:14.600 [INFO] “oled_page_disk”,
26/07/29 16:32:14.600 [INFO] “gpio_fan_state”,
26/07/29 16:32:14.600 [INFO] “ws2812”,
26/07/29 16:32:14.600 [INFO] “gpio_fan_mode”,
26/07/29 16:32:14.600 [INFO] “memory”,
26/07/29 16:32:14.600 [INFO] “oled_sleep”,
26/07/29 16:32:14.600 [INFO] “cpu_temperature”,
26/07/29 16:32:14.600 [INFO] “shutdown”
26/07/29 16:32:14.600 [INFO] ],
26/07/29 16:32:14.600 [INFO] “version”: “1.3.18”,
26/07/29 16:32:14.601 [INFO] “app_name”: “pironman5”,
26/07/29 16:32:14.601 [INFO] “config_path”: “/opt/pironman5/config.json”
26/07/29 16:32:14.601 [INFO] }
26/07/29 16:32:14.601 [INFO] PM_Auto version: 2.0.5
26/07/29 16:32:14.601 [INFO] PM_Dashboard version: 2.0.3
26/07/29 17:14:38.622 [INFO]
26/07/29 17:14:38.623 [INFO] ############################################################
26/07/29 17:14:38.623 [INFO] Pironman5 Start
26/07/29 17:14:38.623 [INFO] Pironman5 version: 1.3.18
26/07/29 17:14:38.623 [INFO] Variant: Pironman 5 Max V2
26/07/29 17:14:38.623 [INFO] Config:
26/07/29 17:14:38.623 [INFO] {
26/07/29 17:14:38.623 [INFO] “system”: {
26/07/29 17:14:38.623 [INFO] “data_interval”: 1,
26/07/29 17:14:38.623 [INFO] “database_retention_days”: 30,
26/07/29 17:14:38.623 [INFO] “temperature_unit”: “C”,
26/07/29 17:14:38.623 [INFO] “enable_history”: true,
26/07/29 17:14:38.623 [INFO] “oled_enable”: true,
26/07/29 17:14:38.623 [INFO] “oled_rotation”: 0,
26/07/29 17:14:38.623 [INFO] “oled_sleep_timeout”: 10,
26/07/29 17:14:38.624 [INFO] “oled_pages”: [“mix”, “battery”, “input”, “rpi_power”],
26/07/29 17:14:38.624 [INFO] “rgb_enable”: true,
26/07/29 17:14:38.624 [INFO] “rgb_color”: “#0a1aff”,
26/07/29 17:14:38.624 [INFO] “rgb_brightness”: 100,
26/07/29 17:14:38.624 [INFO] “rgb_style”: “breathing”,
26/07/29 17:14:38.624 [INFO] “rgb_speed”: 50,
26/07/29 17:14:38.624 [INFO] “rgb_led_count”: 4,
26/07/29 17:14:38.624 [INFO] “rgb_led_count_min”: 4,
26/07/29 17:14:38.624 [INFO] “gpio_fan_pin”: 6,
26/07/29 17:14:38.624 [INFO] “gpio_fan_mode”: 0,
26/07/29 17:14:38.624 [INFO] “gpio_fan_led”: “follow”,
26/07/29 17:14:38.624 [INFO] “gpio_fan_led_pin”: 5,
26/07/29 17:14:38.624 [INFO] “shutdown_percentage”: 10,
26/07/29 17:14:38.624 [INFO] “send_email_on”: [“low_battery”, “power_disconnected”, “power_restored”, “power_insufficient”, “battery_critical_shutdown”, “battery_voltage_critical_shutdown”],
26/07/29 17:14:38.624 [INFO] “send_email_to”: “”,
26/07/29 17:14:38.624 [INFO] “smtp_email”: “”,
26/07/29 17:14:38.624 [INFO] “smtp_password”: “”,
26/07/29 17:14:38.624 [INFO] “smtp_server”: “”,
26/07/29 17:14:38.624 [INFO] “smtp_port”: 465,
26/07/29 17:14:38.624 [INFO] “smtp_security”: “ssl”,
26/07/29 17:14:38.624 [INFO] “pipower5_buzzer_volume”: 5,
26/07/29 17:14:38.624 [INFO] “pipower5_buzz_on”: [“battery_activated”, “low_battery”, “power_disconnected”, “power_restored”, “power_insufficient”, “battery_critical_shutdown”, “battery_voltage_critical_shutdown”],
26/07/29 17:14:38.624 [INFO] “pipower5_buzz_sequence”: {“battery_activated”: [[“A4”, 200], [“pause”, 100], [“B4”, 200]], “low_battery”: [[“A4”, 250], [“pause”, 150], [“A4”, 250]], “power_disconnected”: [[“D5”, 150], [“G4”, 150]], “power_restored”: [[“G4”, 150], [“D5”, 150]], “power_insufficient”: [[“B4”, 200], [“pause”, 100], [“B4”, 200], [“pause”, 100], [“B4”, 300]], “battery_critical_shutdown”: [[“C6”, 120], [“pause”, 60], [“C6”, 120], [“pause”, 60], [“C6”, 400]], “battery_voltage_critical_shutdown”: [[“C6”, 120], [“pause”, 60], [“C6”, 120], [“pause”, 60], [“C6”, 400], [“pause”, 60], [“C6”, 400]]},
26/07/29 17:14:38.624 [INFO] “debug_level”: “INFO”
26/07/29 17:14:38.624 [INFO] }
26/07/29 17:14:38.625 [INFO] Device info:
26/07/29 17:14:38.625 [INFO] {
26/07/29 17:14:38.625 [INFO] “name”: “Pironman 5 Max”,
26/07/29 17:14:38.625 [INFO] “id”: “pironman5-max”,
26/07/29 17:14:38.625 [INFO] “peripherals”: [
26/07/29 17:14:38.625 [INFO] “memory”,
26/07/29 17:14:38.625 [INFO] “history”,
26/07/29 17:14:38.625 [INFO] “gpio_fan_state”,
26/07/29 17:14:38.625 [INFO] “gpu_temperature”,
26/07/29 17:14:38.625 [INFO] “reboot”,
26/07/29 17:14:38.625 [INFO] “oled”,
26/07/29 17:14:38.625 [INFO] “output_power”,
26/07/29 17:14:38.625 [INFO] “send_email”,
26/07/29 17:14:38.625 [INFO] “shutdown”,
26/07/29 17:14:38.625 [INFO] “gpio_fan_led”,
26/07/29 17:14:38.625 [INFO] “oled_page_performance”,
26/07/29 17:14:38.625 [INFO] “log”,
26/07/29 17:14:38.625 [INFO] “ws2812”,
26/07/29 17:14:38.625 [INFO] “is_input_plugged_in”,
26/07/29 17:14:38.625 [INFO] “delete_log_file”,
26/07/29 17:14:38.625 [INFO] “battery_voltage”,
26/07/29 17:14:38.625 [INFO] “is_charging”,
26/07/29 17:14:38.625 [INFO] “oled_page_mix”,
26/07/29 17:14:38.625 [INFO] “oled_page_disk”,
26/07/29 17:14:38.625 [INFO] “pi5_power_button”,
26/07/29 17:14:38.625 [INFO] “cpu_temperature”,
26/07/29 17:14:38.625 [INFO] “oled_page_input”,
26/07/29 17:14:38.626 [INFO] “output_voltage”,
26/07/29 17:14:38.626 [INFO] “restart_service”,
26/07/29 17:14:38.626 [INFO] “pipower5_buzzer”,
26/07/29 17:14:38.626 [INFO] “battery_percentage”,
26/07/29 17:14:38.626 [INFO] “default_on”,
26/07/29 17:14:38.626 [INFO] “oled_page_rpi_power”,
26/07/29 17:14:38.626 [INFO] “power-failure-simulation”,
26/07/29 17:14:38.626 [INFO] “cpu”,
26/07/29 17:14:38.626 [INFO] “pipower5”,
26/07/29 17:14:38.626 [INFO] “pipower5_buzzer_volume”,
26/07/29 17:14:38.626 [INFO] “input_current”,
26/07/29 17:14:38.626 [INFO] “mac_address”,
26/07/29 17:14:38.626 [INFO] “network”,
26/07/29 17:14:38.626 [INFO] “pipower5_buzz_on”,
26/07/29 17:14:38.626 [INFO] “power_source”,
26/07/29 17:14:38.626 [INFO] “battery_current”,
26/07/29 17:14:38.626 [INFO] “oled_sleep”,
26/07/29 17:14:38.626 [INFO] “input_voltage”,
26/07/29 17:14:38.626 [INFO] “gpio_fan_mode”,
26/07/29 17:14:38.626 [INFO] “output_current”,
26/07/29 17:14:38.626 [INFO] “data_interval”,
26/07/29 17:14:38.626 [INFO] “oled_page_battery”,
26/07/29 17:14:38.626 [INFO] “pwm_fan_speed”,
26/07/29 17:14:38.626 [INFO] “temperature_unit”,
26/07/29 17:14:38.626 [INFO] “shutdown_percentage”,
26/07/29 17:14:38.626 [INFO] “clear_history”,
26/07/29 17:14:38.626 [INFO] “storage”,
26/07/29 17:14:38.626 [INFO] “ip_address”,
26/07/29 17:14:38.626 [INFO] “oled_page_ips”,
26/07/29 17:14:38.626 [INFO] “debug_level”
26/07/29 17:14:38.627 [INFO] ],
26/07/29 17:14:38.627 [INFO] “version”: “1.3.18”,
26/07/29 17:14:38.627 [INFO] “app_name”: “pironman5”,
26/07/29 17:14:38.627 [INFO] “config_path”: “/opt/pironman5/config.json”
26/07/29 17:14:38.627 [INFO] }
26/07/29 17:14:38.627 [INFO] PM_Auto version: 2.0.5
26/07/29 17:14:38.627 [INFO] PM_Dashboard version: 2.0.3
26/07/31 09:03:32.225 [INFO]
26/07/31 09:03:32.226 [INFO] ############################################################
26/07/31 09:03:32.226 [INFO] Pironman5 Start
26/07/31 09:03:32.226 [INFO] Pironman5 version: 1.3.18
26/07/31 09:03:32.226 [INFO] Variant: Pironman 5 Max V2
26/07/31 09:03:32.226 [INFO] Config:
26/07/31 09:03:32.226 [INFO] {
26/07/31 09:03:32.226 [INFO] “system”: {
26/07/31 09:03:32.226 [INFO] “data_interval”: 1,
26/07/31 09:03:32.226 [INFO] “database_retention_days”: 30,
26/07/31 09:03:32.226 [INFO] “temperature_unit”: “C”,
26/07/31 09:03:32.226 [INFO] “enable_history”: true,
26/07/31 09:03:32.226 [INFO] “oled_enable”: true,
26/07/31 09:03:32.227 [INFO] “oled_rotation”: 0,
26/07/31 09:03:32.227 [INFO] “oled_sleep_timeout”: 10,
26/07/31 09:03:32.227 [INFO] “oled_pages”: [“mix”, “battery”, “input”, “rpi_power”],
26/07/31 09:03:32.227 [INFO] “rgb_enable”: true,
26/07/31 09:03:32.227 [INFO] “rgb_color”: “#0a1aff”,
26/07/31 09:03:32.227 [INFO] “rgb_brightness”: 100,
26/07/31 09:03:32.227 [INFO] “rgb_style”: “breathing”,
26/07/31 09:03:32.227 [INFO] “rgb_speed”: 50,
26/07/31 09:03:32.227 [INFO] “rgb_led_count”: 4,
26/07/31 09:03:32.227 [INFO] “rgb_led_count_min”: 4,
26/07/31 09:03:32.227 [INFO] “gpio_fan_pin”: 6,
26/07/31 09:03:32.227 [INFO] “gpio_fan_mode”: 0,
26/07/31 09:03:32.227 [INFO] “gpio_fan_led”: “follow”,
26/07/31 09:03:32.227 [INFO] “gpio_fan_led_pin”: 5,
26/07/31 09:03:32.227 [INFO] “shutdown_percentage”: 10,
26/07/31 09:03:32.227 [INFO] “send_email_on”: [“low_battery”, “power_disconnected”, “power_restored”, “power_insufficient”, “battery_critical_shutdown”, “battery_voltage_critical_shutdown”],
26/07/31 09:03:32.227 [INFO] “send_email_to”: “”,
26/07/31 09:03:32.227 [INFO] “smtp_email”: “”,
26/07/31 09:03:32.227 [INFO] “smtp_password”: “”,
26/07/31 09:03:32.227 [INFO] “smtp_server”: “”,
26/07/31 09:03:32.227 [INFO] “smtp_port”: 465,
26/07/31 09:03:32.227 [INFO] “smtp_security”: “ssl”,
26/07/31 09:03:32.227 [INFO] “pipower5_buzzer_volume”: 5,
26/07/31 09:03:32.227 [INFO] “pipower5_buzz_on”: [“battery_activated”, “low_battery”, “power_disconnected”, “power_restored”, “power_insufficient”, “battery_critical_shutdown”, “battery_voltage_critical_shutdown”],
26/07/31 09:03:32.227 [INFO] “pipower5_buzz_sequence”: {“battery_activated”: [[“A4”, 200], [“pause”, 100], [“B4”, 200]], “low_battery”: [[“A4”, 250], [“pause”, 150], [“A4”, 250]], “power_disconnected”: [[“D5”, 150], [“G4”, 150]], “power_restored”: [[“G4”, 150], [“D5”, 150]], “power_insufficient”: [[“B4”, 200], [“pause”, 100], [“B4”, 200], [“pause”, 100], [“B4”, 300]], “battery_critical_shutdown”: [[“C6”, 120], [“pause”, 60], [“C6”, 120], [“pause”, 60], [“C6”, 400]], “battery_voltage_critical_shutdown”: [[“C6”, 120], [“pause”, 60], [“C6”, 120], [“pause”, 60], [“C6”, 400], [“pause”, 60], [“C6”, 400]]},
26/07/31 09:03:32.227 [INFO] “debug_level”: “INFO”
26/07/31 09:03:32.227 [INFO] }
26/07/31 09:03:32.228 [INFO] }
26/07/31 09:03:32.228 [INFO] Device info:
26/07/31 09:03:32.228 [INFO] {
26/07/31 09:03:32.228 [INFO] “name”: “Pironman 5 Max”,
26/07/31 09:03:32.228 [INFO] “id”: “pironman5-max”,
26/07/31 09:03:32.228 [INFO] “peripherals”: [
26/07/31 09:03:32.228 [INFO] “debug_level”,
26/07/31 09:03:32.228 [INFO] “pwm_fan_speed”,
26/07/31 09:03:32.228 [INFO] “is_input_plugged_in”,
26/07/31 09:03:32.228 [INFO] “cpu_temperature”,
26/07/31 09:03:32.228 [INFO] “delete_log_file”,
26/07/31 09:03:32.228 [INFO] “clear_history”,
26/07/31 09:03:32.228 [INFO] “log”,
26/07/31 09:03:32.228 [INFO] “oled_page_performance”,
26/07/31 09:03:32.228 [INFO] “restart_service”,
26/07/31 09:03:32.228 [INFO] “default_on”,
26/07/31 09:03:32.228 [INFO] “output_power”,
26/07/31 09:03:32.228 [INFO] “data_interval”,
26/07/31 09:03:32.228 [INFO] “mac_address”,
26/07/31 09:03:32.228 [INFO] “history”,
26/07/31 09:03:32.228 [INFO] “oled”,
26/07/31 09:03:32.228 [INFO] “is_charging”,
26/07/31 09:03:32.228 [INFO] “oled_page_ips”,
26/07/31 09:03:32.228 [INFO] “power_source”,
26/07/31 09:03:32.228 [INFO] “output_voltage”,
26/07/31 09:03:32.228 [INFO] “memory”,
26/07/31 09:03:32.229 [INFO] “oled_page_mix”,
26/07/31 09:03:32.229 [INFO] “output_current”,
26/07/31 09:03:32.229 [INFO] “storage”,
26/07/31 09:03:32.229 [INFO] “oled_sleep”,
26/07/31 09:03:32.229 [INFO] “gpio_fan_mode”,
26/07/31 09:03:32.229 [INFO] “battery_percentage”,
26/07/31 09:03:32.229 [INFO] “oled_page_battery”,
26/07/31 09:03:32.229 [INFO] “input_current”,
26/07/31 09:03:32.229 [INFO] “pipower5”,
26/07/31 09:03:32.229 [INFO] “pipower5_buzz_on”,
26/07/31 09:03:32.229 [INFO] “input_voltage”,
26/07/31 09:03:32.229 [INFO] “shutdown_percentage”,
26/07/31 09:03:32.229 [INFO] “temperature_unit”,
26/07/31 09:03:32.229 [INFO] “pipower5_buzzer”,
26/07/31 09:03:32.229 [INFO] “cpu”,
26/07/31 09:03:32.229 [INFO] “gpu_temperature”,
26/07/31 09:03:32.229 [INFO] “ip_address”,
26/07/31 09:03:32.229 [INFO] “power-failure-simulation”,
26/07/31 09:03:32.229 [INFO] “oled_page_input”,
26/07/31 09:03:32.229 [INFO] “battery_current”,
26/07/31 09:03:32.229 [INFO] “send_email”,
26/07/31 09:03:32.229 [INFO] “oled_page_disk”,
26/07/31 09:03:32.229 [INFO] “gpio_fan_state”,
26/07/31 09:03:32.229 [INFO] “gpio_fan_led”,
26/07/31 09:03:32.229 [INFO] “reboot”,
26/07/31 09:03:32.229 [INFO] “shutdown”,
26/07/31 09:03:32.229 [INFO] “pipower5_buzzer_volume”,
26/07/31 09:03:32.229 [INFO] “oled_page_rpi_power”,
26/07/31 09:03:32.229 [INFO] “pi5_power_button”,
26/07/31 09:03:32.229 [INFO] “battery_voltage”,
26/07/31 09:03:32.230 [INFO] “network”,
26/07/31 09:03:32.230 [INFO] “ws2812”
26/07/31 09:03:32.230 [INFO] ],
26/07/31 09:03:32.230 [INFO] “version”: “1.3.18”,
26/07/31 09:03:32.230 [INFO] “app_name”: “pironman5”,
26/07/31 09:03:32.230 [INFO] “config_path”: “/opt/pironman5/config.json”
26/07/31 09:03:32.230 [INFO] }
26/07/31 09:03:32.230 [INFO] PM_Auto version: 2.0.5
26/07/31 09:03:32.230 [INFO] PM_Dashboard version: 2.0.3
Thank you for sharing your findings. It does appear that the software may have a compatibility issue with the newer Bookworm system. We will look into this and try to resolve it.
Since Trixie is working for you, it’s a good idea to continue using that version for now.
