Different versions of the robot hat?
In my kit is a robot hat 3.3, it resembles the drawing in the paper assembly manual. But in the online manuals there is a different robot hat having an usb-c connector amongst others. Also the online instructions mention using that usb-c connector to charge the batteries as well as the videos and graphics using that version.
Are there differences in functionality between the versions? Can I charge the batteries with my version 3.3 robot hat?
How can i obtain the (newer?) robot hat? and would that solve my problems?
Kind regards,
Pea
ps; the box has a sticker: CN0351D picar-x 2023.10.20 does that help determining the version?
Hi Pea,
Thank you very much for describing your question in such detail, and for taking the time to go through our online manuals. We are sorry for the confusion, and we are glad to help you sort out the version and functionality questions.
Let me answer your questions directly:
About the version differences: The Robot HAT 3.3 in your kit is an earlier version, while the one with the USB-C connector shown in the online manuals is a newer Robot HAT version, so there are indeed hardware differences between them (for example, the newer version has a USB-C connector). However, for the exact differences in each function, we need to refer to the official documentation and first confirm the exact version of the board you have, so that we can give you an accurate comparison and avoid misleading you.
About whether you can charge the batteries with your version 3.3 Robot HAT: This also depends on the hardware specifications of that board version. Before confirming the version of your board, we would rather not give a definite answer, so as not to provide you with incorrect information.
About how to obtain the newer Robot HAT and whether replacing it would solve your problems: This requires first confirming the version of your current board and your actual usage needs. Once confirmed, we will explain the available options (such as whether the newer Robot HAT can be purchased separately).
About the box sticker CN0351D picar-x 2023.10.20: This information can help us determine the production batch and date, but on its own we cannot directly determine the specific version of the Robot HAT; we will need to check the actual photos to confirm.
To accurately confirm your version and give you the corresponding answer, please provide the following:
Photos of the actual Robot HAT (it is best to clearly capture the front of the board and the side with the connectors, so that the silkscreen and connector types are visible);
A photo of the sticker on the box (including the CN0351D picar-x 2023.10.20 information).
Upload reminder: Please upload the photos to Google Drive (or another cloud drive), then send us the sharing link, and set the link permission in the cloud drive to “Anyone with the link can view”; otherwise we will not be able to view your files.
Once we receive the photos, we will confirm the version as soon as possible and give you a clear answer regarding the functional differences, charging method, and upgrade/replacement options. Thank you again for your patience and understanding, and please feel free to contact us if you have any other questions.
Thank you for your reply.
Here is the link to the pictures of the robot hat and all the stickers (2) on the box, I hope these provide you with all the information you need.
regards, Pea
Thank you for providing the photos and for your patience. We have reviewed the images you uploaded and confirmed that you are using an early version of the Robot HAT 3.3 (the version that uses an 18650 battery). Here are our answers to your questions:
Charging: This version of the Robot HAT cannot supply power to or charge the 18650 battery through the HAT. In other words, this version does not support charging the battery via the HAT.
Code compatibility: The code for this version has been updated through several iterations, and the older code cannot be used directly with the current product. You would need to upgrade the Robot HAT to use it.
Upgrade option: Upgrading to the Robot HAT V4 (together with the battery and related accessories) should be compatible in theory, and it will work with the latest picar-x-v20 code.
Thank you for answer.
So I seem to have bought an incompatible kit, software isn’t available online and the solution you offer is to buy a V4 robot board roughly about half the price of the complete kit. I find this somewhat disappointing.
Back when I bought the kit it was my aim to buy the picar-x V2 but obviously that didn’t work out, a pity that it only became clear after a long time or I would have returned the kit right away.
Thanks again for your help determining the incompatibility, it saves me from fruitlessly trying something impossible.
One last question: Would you see a possibility to swap my kit for a picar-x 2.0 kit?
Kind regards,
Pea
To upgrade your current setup to PiCar-X V2, you will need to replace two components:
Robot HAT V4
3‑pin battery
You can purchase both parts directly from us. To arrange the order and get pricing, please contact our service team at service@sunfounder.com — they will assist you with availability, pricing, and ordering.
I will mail service@sunfounder.com
thanks, Pea
