EZ-Block connection refused on video
so i’m using picar x with raspberry 5 and the image Microsoft OneDrive for raspberry 5. Everything works but not the video streaming. I have a connection refused error on the browser in ezblock and on the console I see http://192.168.1.62:9000/mjpg?a=1771072795000 error, so I’m trying to figure out if port 9000 is on on the Raspberry Pi but it isn’t and there’s no video service. How can I fix this? Thanks
Try opening this page in your browser: http://192.168.1.62:9000/mjpg
Check if you can see the video feed.
Check the camera connections and try reconnecting the camera ribbon cable. If it still doesn’t work, try replacing the camera ribbon cable.
If possible, connect a monitor, mouse, and keyboard, then enter the following command in the terminal:
libcamera-hello
and see if any error messages appear.
