Ezblock Studio web connection refused on picar-x using camera
I try to run the examples with video detections, like Bullfight or Color Detection.
But it does not show the video stream.
it says IP adress of Picar-x 192.168.xx.xxx connection refused.
But I can take pictures on the pi via ssh and they look good.
Connection: WiFi
Image: Raspios-buster-armhf-lite-2021-1-11_EzBlockOS-v1.2.3
Raspberrd Pi zero 2 W
When trying to use the iOS App on my iPad Air, it shows a white screen at the video widget. But the app only connects with Bluetooth, no option to do it via WiFi.
Any suggestions?
1.What version of the iPad Air do you have, and what is the system version? Please let us know so that we can replicate and resolve the issue.
2.We recommend recording a video of the process for us to help you analyze and solve the problem.
If the video file is large, please upload it to OneDrive and share the link with us, granting us access permission.
iPad Air 5. Generation iOs 16.1
EzBlock App on iOs v.3.2.140
on Laptop Win 11, EzBlock Studio 3.2.137
Connecting via Wifi 2.4
Raspberry Pi Zero W Rev 1.1
1.What version of iPad Air do you have, and what is the system version? Please let us know so we can replicate the issue and find a solution.
2.We recommend that you record a video of the process to help us analyze and resolve the problem. If the video file size is large, please upload it to OneDrive and share the link with us, granting us access.
As I wrote i my answer, iPad Air 5. Generation.
But the main problem is the web version on laptop. And I simply start the bullfight and get this view on the video widget.
There are no additioal steps involved that could be shown on a video.
All examples without the camera work.
But I solved the problem by changing the Pi to a 4B. Now everything is working fine. Also the lag of the remote control is gone.
Simple conclusion- Pi Zero is not a good choice
But be aware, when changing the board, you have to reset the servos again, so you have to be careful. Better disassembling at least the tilt servo. It just turned a little bit on all servos
We recommend using the Raspberry Pi 5/4/3B+/3B/Zero 2W.
Raspberry Pi 4 is the best choice.
