Hi. Is there any update on compatibility of EzBlock with Raspberry Pi5.
I am trying to connect Picrawler /Rpi5, however connection is failing / not available.
Any plans for that?
Any plans for that?
Are you using the web version of EzBlock and experiencing a connection failure?If so, the issue is likely due to a recent change in Google Chrome that blocks local network access by default.
Solution – Try a different browser:
Please use Firefox instead of Chrome. Firefox should connect to the EzBlock webpage without issues.
Alternative solution – Modify Chrome settings:
If you prefer to continue using Chrome, you can manually disable the local network access check:
In Chrome, type the following address into the address bar:
chrome://flags/#local-network-access-check
Set the “Local Network Access Checks” option to Disabled.Restart Chrome (close and reopen the browser).Open the EzBlock webpage again:
After this change, the connection should work.
Are you using a mobile device instead, and cannot see the PiCrawler’s Bluetooth in the EzBlock app?If so, please try the following:Turn on location sharing (GPS / location services) on your mobile device.Restart the EzBlock application.Let me know if this resolves your issue.
