Is the newest version of Home Assistant 16.x officially supported?
Thanks,
-hyp
Thanks,
-hyp
Could you please let us know which of our products are you using?
How does Home Assistant 16 work in conjunction with our products?
About the problem you mentioned, could you please send a short video or some pictures of the product issue so we can know it better.
If the video memory is large, please upload the recorded video to onedrive, share the video link with us.
I am using a Pironman 5 Max with a Raspberry Pi 5 running Home Assistant 16. When I installed the plugin I had issues with the system halting. I tried downgrading to Home Assistant 15 but this didn’t help. So I am now running on version 16 but without the Pironman plugins – but the fans don’t work of course. What is the current support for Home Assistant 16?
Home Assistant 16 is compatible with our Pironman5 Max plugin. Are you sure you have installed the Pironman5 Max plugin? (See the attached image.)
We suggest you provide us with log information so that we can help you analyze and resolve the issue.
When you say the fan is not working, are you referring to the RGB fan?
Please check if there are jumpers connected to the FAN6 and FLED5 pins at the J2 position on the IO expansion board. (See the attached image.)
