Pi-Crawler not connecting to Ezblock studio
Hi there,
I got myself and my son a Pi-crawler with the Raspberry 4. The building part was fine. I installed the latest build of Ezblock on the microsd card and I do get the welcome sound when powering up the Pi-crawler. I must say that the customisation tab was greyed out before writing it on the sd so I couldn’t setup a hostname.
Once I got the power sound and check on ezblock website I can’t connect because I don’t have the hostname. I tried ‘Raspberry’, ‘Raspberrypi’ and ‘raspberrypi-ezb’ but it fails each time. When I try to connect with the ios ezblock app, it does detect the rasbperrypi and there is a MAC address under it. But when I click on it it says “Bluetooth connection failed, please try again”.
My ios is up to date. Can you give me a hand ?
Possibly same as this?
Thank you, Yes !
Although he says he’s able to connect with a “network cable” I tried ethernet but it doesn’t do anything.
Just to be clear, he has the same issue as me but seems he hasn’t found an answer yet …
I apologise, I may have misunderstood both of your requirements then.
I thought that the other poster had got it working with 1.75, allowing password set up etc which I thought was your requirement, but that they then also wanted a direct method to run rather than via a Web interface?
Sorry, if i misunderstood!
Silly me ! Sorry I didn’t see the answers below the first message, I’m gonna try to find the 1.7.5 now, thank you again
Hope you get it working for your son.
If not, Sunfounder should be back in the office after the weekend, and to be honest their support is really good.
It worked !!! I used the 1.9.6 build and could customise the ssh and connect !:slight_smile:
Thanks a lot !
