I am looking for the default login for easyblockOS. While writing the image using raspberry pi imager 2.03, the customization option is not selectable. When booting to the image on the rpi, ssh keys are setup then it reboots to cli. I tried logging in using default ‘pi’ and pw ‘raspberry’ but login fails. I can connect to the pi with easyblocks web, but only if pi is connected by network cable. I also tried an earlier version of rpi imager (1.05) with same results and no config option. Can somebody give me an idea of what i’m missing?
We have also encountered the same issue; this is a known bug in Raspberry Pi Imager 2.03.
If you need to install a custom system image, it is recommended to use a version of Raspberry Pi Imager lower than 2.0 (excluding version 2.0 itself).
Theoretically, the default credentials for a newly installed system are:
Username: pi
Password: raspberry
However, the actual result is not consistent with this.
I tried version 1.7.5 and was able to write to a sd card but only a 32g.
Is there no version of easyblocks that run on the pi directly? So far from what I see is all programming has to be done through the web interface.
Thanks
If you want to use EZBlock Studio to control the robot, it is currently only possible by downloading and installing our specified EZBlock OS image system in order to establish a proper connection and operation.
