Picar-x v3 start niet
Picar-x v3
hallo ik heb een probleem met het instaleren van de i2 module zodra hij reboot dan valt de verbinding weg en reboot hij niet en start ook niet opnieuw op.
wat kan ik hieraan doen.
Install i2?
Please follow the steps in our tutorial to install all the library code:
https://docs.sunfounder.com/projects/picar-x-v20/en/latest/python/python_start/install_all_modules.html
If you encounter any issues at any step, please describe the problem in detail, or provide screenshots or video of the issue to help us analyze and resolve it.
We recommend connecting a display to your Raspberry Pi to easily observe its startup status.
Hello, whatever I try it disconnects directly when you press y for reboot at the last module and breaks the connection. I also tried it with a screen directly on the robotcar but that is the same problem.
(Attachment picar-x disconnect.docx4.docx is missing)
(attachments)
It’s difficult to read all of what’s on the screenshot, however pressing “y” is supposed to reboot the rpi4, which will then disconnect from your client.
So, from what is on screen it is all behaving correctly.
After you run the script without error , then that is the amp configured, but it needs to reboot for those changes to “stick”
After it’s finished booting, reconnect with ssh or whatever, and then try to run some of the audio examples.
However, There is an error reported with pinctrl.
You may need to run the script a few times i2samp.sh
If you get an error, Type N (uppercase) when asked whether to reboot
Then run i2samp.sh again
Repeat until no errors, then press “y”
Reboot and then try the examples.
