Hi. I have Piroman v.2.0 with Home Assistant v.11.1 OS installed on the SSD. Everything works fine, but the display says “DISCONNECT” instead of the LAN IP address.The computer is powered by the original Raspberry Pi 5.1v 3A unit. When Wi-Fi is connected, the IP address is displayed correctly. Please tell me how can I fix the problem?
Add-on: Pironman
Pironman support
Add-on version: 1.0.7
System: Home Assistant OS 11.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.11.1
Home Assistant Supervisor: 2023.11.0
[21:57:17] INFO: Configuring timezone (Europe/Moscow)…
temperature_unit: C
fan_temp: 55
display_always_on: false
display_on_for: 180
rgb_on: true
rgb_style: breath
rgb_color: FF00FF
rgb_speed: 20
rgb_freq: 1000
rgb_pin: 10
set temperature unit to C
set the fan on temperature to 55
set screen_always_on to off
set screen_off_time to 180
set rgb_enable to on
set rgb_switch to on
set rgb_style to breath
set rgb_color to FF00FF
set rgb_blink_speed to 20
set rgb_pwm_freq to 1000
set rgb io to pin 10 (spi)
restarting pironman
stopping pironman
pid=263
run in foreground
23/11/08 21:57:20,618 [DEBUG] Home Assistant Addon mode
------------------------23/11/08 21:57:20------------------------
pironman version: 2.2.3
username:
Kernel Version:
Linux 6fa7f6d2-pironman 6.1.21-v8 #1 SMP Thu Oct 26 14:39:03 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
PCB info:
Revision : c03115
23/11/08 21:57:20,666 [DEBUG] power_key_pin : 16
23/11/08 21:57:20,667 [DEBUG] fan_pin : 6
23/11/08 21:57:20,667 [DEBUG] update_frequency : 0.5
23/11/08 21:57:20,668 [DEBUG] temp_unit : C
23/11/08 21:57:20,668 [DEBUG] fan_temp : 55.0
23/11/08 21:57:20,669 [DEBUG] screen_always_on : False
23/11/08 21:57:20,669 [DEBUG] screen_off_time : 180
23/11/08 21:57:20,669 [DEBUG] rgb_enable : True
23/11/08 21:57:20,670 [DEBUG] rgb_switch: True
23/11/08 21:57:20,670 [DEBUG] rgb_style : breath
23/11/08 21:57:20,671 [DEBUG] rgb_color : FF00FF
23/11/08 21:57:20,671 [DEBUG] rgb_blink_speed : 20
23/11/08 21:57:20,672 [DEBUG] rgb_pwm_freq : 1000
23/11/08 21:57:20,672 [DEBUG] rgb_pin : 10
23/11/08 21:57:20,673 [DEBUG]
23/11/08 21:57:20,690 [DEBUG] oled init success
23/11/08 21:57:20,709 [DEBUG] rgb_show
23/11/08 21:57:20,710 [DEBUG] rgb_show: breath
23/11/08 21:57:20,929 [DEBUG] Got IPs: {‘end0’: ‘192.168.1.7’}
getCPUuse: could not convert string to float: ‘id.\n’
23/11/08 21:57:21,775 [DEBUG] Got IPs: {‘end0’: ‘192.168.1.7’}
