Pironman 5 case fan hysteresis?
Is it possible to change the hysteresis for the RGB fans (not the tower fan)? Would prefer it to be 10 degrees instead of 5, ideally. When running high-stress applications, the temperature quickly drops five degrees below the spin-up temperature of 60 degrees and turns them off, and then takes little time to get back to 60. The constant fluctuating is kind of distracting. Wouldn’t mind so much if it was possible to disable the LEDs on the fans, since I barely hear them when they’re running anyway.
The non-PWM RGB fans (GPIO-controlled) in the Pironman5 case do not support direct adjustment of the hysteresis value via software.
The pironman5 service and its web dashboard only provide 5 fixed modes (Quiet/Balanced/Cool/Performance/Always On), with no option for customizing the hysteresis.
