Pironman 5 MAX excessive logging
Is there a way how to reduce excessive log activity of pironman max in HA OS Supervisor logs?
My Supervisor log is full of pironman info logs:
2026-02-13 10:41:07.969 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:08.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:08.969 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:09.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:09.968 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:10.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:10.975 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:11.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:11.969 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:12.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:12.971 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:13.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:13.970 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:14.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:14.970 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:15.942 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
2026-02-13 10:41:15.969 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 6fa7f6d2_pironman5-max
It seems there is no way to hide this log. This is printed by Home Assistant itself when we use its interface to obtain the device’s IP. We have no control over it. Alternatively, you could try modifying the Home Assistant log level to suppress info messages.
Run this once from the HA Terminal / SSH add-on:
curl -sSL -X POST
-H “Authorization: Bearer $SUPERVISOR_TOKEN”
-H “Content-Type: application/json”
http://supervisor/supervisor/options``
-d ‘{“logging”:“error”}’
Followed by the following:
curl -sSL -X POST
http://supervisor/supervisor/reload
These above command stops “INFO” logs entirely in the supervisor and enabling “ERROR” ones for now. This is a temporary fix, but a working one.
