Hello.
I noticed that the pironman5 service writes, when it is active, to a file directly in the root /1 (the file name is 1). This file grows continuously and can reach very large sizes. How can I disable this?
Please check out our tutorials:
https://docs.sunfounder.com/projects/pironman5/en/latest/control/control_with%20dashboard.html#log
You can delete the extra log log file’s.
Hello. Thanks for the hint, but the problem is not in the logs that are written to /var/log/pirionman5, these logs really behave correctly.
I am referring to the log that is written directly to root (in my case the log has the name 1 all the time).
At first glance it seems to be an InfluxDB log, and at one point when problems arose with the piroman5 service, the log grew to 10 GB in a very short time (2-3 hours). Considering that the log writes continuously, it practically reduces the lifespan of the disk, be it NMVE or SSD or SDCARD. The idea of ​​the dashboard itself is very ok, but I am interested in other services working correctly. I bought the case for better ventilation for the PI 5, but considering the behavior of the service, I basically have to stop the pironman5 service. I noticed that there is further development, which gives me hope, but even after the last update the log in the root persists.
We have fixed the problem you reported.
You can just update and install the pironman5 software again.
cd ~/pironman5
git pull
Thanks for the fixing. At first glance everything seems to be working fine.
This does not work at all: On the contrary. Now the old configuration to switch off the LEDs has disappeared.
This is written EVERY second into syslog directly:
journalctl -u pironman5 -f
Dec 02 11:43:53 server pironman5[948]: [httpd] ::1 - root [02/Dec/2025:11:43:53 +0100] “GET /ping HTTP/1.1” 204 0 “-” “python-requests/2.28.1” cb73bbe6-cf6b-1
1f0-803c-2ccf6788e2d4 24
Dec 02 11:43:53 server pironman5[948]: [httpd] ::1 - root [02/Dec/2025:11:43:53 +0100] "POST /write?db=pironman5 HTTP/1.1 " 204 0 “-” “python-requests/2.28.1”
cb73e920-cf6b-11f0-803d-2ccf6788e2d4 3815
Dec 02 11:43:54 server pironman5[948]: [httpd] ::1 - root [02/Dec/2025:11:43:54 +0100] “GET /ping HTTP/1.1” 204 0 “-” “python-requests/2.28.1” cc09495f-cf6b-1
1f0-803e-2ccf6788e2d4 23
How can one stop this nonsense?
Sorry, these links don’t work anymore
Our Pironman5 software has been updated to a new version.
We recommend that you re-download and install the Pironman5 software by following our online tutorial, and then verify whether the chassis functions and software controls are working normally.
