Hello, I guess this is a main.py issue, because that is the script looking for your IP address.
Anyway, I installed Docker on rapsberry and actually the system has a main IP related to wlan0, and more IPs related to the containers. So, when I switch on the OLED, the IP shown is the one related to the docker bridge, instead of the real one.
Anyone facing the same issue?
We have not reproduced this problem, please run ifconfig, and sudo python3 /opt/pironman/main.py and provide us with screenshots of the information after running.
Hello, support answered that it’s enough to change the interface id in the /opt/pironman/system_status.py, line 69.
Specifically, you should use the interface referring to the correct IP, in my case it is “wlan0” and not “lo” (the loopback). What is not clear is how to regenerate the executable in order to reflect changes.
