Pironman5 and Little-Backup-Box oled Issue
I am trying to turn my Pironman5 setup into a little-backup-box which is a cool project you can find for PI’s on Git Hub for backing up images on the go.
It uses the oled screen that comes with the Pironman5 case and is great. But when I Install the Pironman 5 module it interferes with the lbb’s use of the oled. So I disabled the oled for the piroman 5 module but it seems to still interfere with lbb’s use of the oled still and causes it to flicker.
I disabled the Pironman’s use of the oled with “sudo pironman5 -oe off” is there a better way to disable it from using the screen so I can use it with lbb?
I need the Pironman module mainly to have the hat’s work properly and the RGB fans won’t spin without it for some reason.?
Cheers
Can you provide us with a video of the problem so that we can analyze the problem?
We don’t know your project well enough to reproduce the problem, so we suggest you provide us with more information.
It should be that the i2c, spi of the device is conflicting with the pironman5, which will affect the normal display of the RGB lights as soon as your device is connected to the pironman5 chassis.
