Greetings. Recently bought Pironman5 case and everything works out-of-box except RGB LEDs and OLED screen.
After I’ve wasted a whole week trying to boot screen up I finally discovered something wrong with SCL line. What can I do now? I would be glad to get some advice/solution.
config.txt
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c0=on
dtparam=i2c1=on
dtparam=i2c_arm=on,i2c_arm_baudrate=100000
#dtparam=i2c_vc=on
#dtparam=i2s=on
dtparam=spi=on
#dtparam=sd_poll_once
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[all]
#dtoverlay=w1-gpio
#dtparam=pciex1_gen=3
#dtoverlay=ssd1306
#dtparam=inverted
dtoverlay=sunfounder-pironman5
dtparam=ir=on
#dtoverlay=i2c-gpio
#dtparam=i2c_gpio_sda=2
#dtparam=i2c_gpio_scl=3
#dtparam=i2c_gpio_delay_us=2
#dtparam=bus=0
Also, I tried to connect oscilloscope to the both i2c lines and they works. I don’t understand what to do next.
