Pironman5 Power Button does not Turn Off LED Lights on Batocera OS
I did search the forum but didn’t find an answer.
My Issue:
When I shut down the system using the Batocera OS option, the fans and lights turn off. Perfect!
When I press the physical power button on the Pironman5 the system shuts down but the LED lights on the expansion board stay on. Not perfect. I did try the following options from some of the threads on here.
I did edit this config file.
rpi-eeprom-config -e
POWER_OFF_ON_HALT=1 (changed from 10 to 1)
Thank you.
We apologize for any inconvenience this may have caused. The issue may need to be fixed by the Batocera team in their next version update. Since they are responsible for making the Pironman5 compatible with Batocera, we will need their cooperation to upload the updated version once we have resolved the software issues.
Therefore, the problem will be addressed in the next update of the Batocera OS.
Not trying to hijack this thread, but don’t want to open a new one.
When I did the rpi-eeprom-config -e
I do not have POWER_OFF_ON_HALT=0
Not sure why, can I add that line into command editor and save it to eeprom?
I found the instructions here:
I can’t recall if I added the line of code to the config or if the line existed already but you can add the missing line
POWER_OFF_ON_HALT=1
