I have the pironman5 case with a ssd, and i installed retropie. then wanna uninstall it so i got back to the desktop, and set the pi to boot first from the sd card, but it still boots from the ssd. When i take out the ssd it works fine. When its booted on the ssd it randomly freezes
I dont have an ssd reader so i cant reset it via a pc
Is your system on the SSD cloned from the SD card? If so, you may have overlooked a detail that caused this issue. When cloning the SD card, remember to use a new partition UUID and check the box on the right (as shown in the image).
This is the official forum where someone has encountered this issue; you can check it out for more information. https://forums.raspberrypi.com/viewtopic.php?t=364985 If you currently don’t have an SSD card reader, you will need to install the system on the SD card and then boot from it.
If you need to clone the system to the SSD, remember to use a new partition UUID and check the box on the right.
