Powering pidog during SW development
Hi
I own a pidog. During most SW development, I only need to have the RPI4 powered up not the Robohat. I’d also like to avoid charging and discharging the Li-ion battery more often than necessary. Can I power just the RPI4 directly through it’s own usb-c supply for this purpose? Or must I always go via the robohat?
If you are modifying the code, you can provide external power to the PI4 separately, without needing to power the robot hat. However, if you need to run pidog, you must provide power to the robot hat.
