Raphael Kit Micro Switches do not connect in breadboard
The micro switches that came in the Raphael Kit have really short pins and do not make connection in the breadboard. They just fall over when even bumped.
I tried using the F-M jumper wires but those are too loose.
What gives?
Hello, thank you for reaching out to us. We are sorry to hear that the micro switches are not connecting well in the breadboard. We understand this is frustrating.
First, please rest assured that the short pins of the micro switch and its tendency to come loose on the breadboard are a design feature of this product, not a quality issue. We chose to include micro switches in the Raphael Kit to introduce you to different types of switches — they are more fun to use than regular buttons and offer a different operating experience.
Regarding the issue you encountered, here are some suggestions:
  1. Press it down: After inserting the micro switch into the breadboard, you can press it down a bit to make it sit deeper and more securely.
  2. Change the position: If the micro switch cannot be secured firmly in one position, try moving it to a different spot on the breadboard. The tightness of different holes may vary.
  3. Same function, replaceable: The micro switch functions exactly the same as a regular button. If you find it inconvenient to use, you can simply replace it with a regular button — it will not affect any project functionality.
We hope these suggestions help. If you have any other questions, please feel free to contact us. Thank you for your patience and cooperation!
I looked at options to solder on longer leads and instead ordered a small batch that had longer leads.
