Raspberry Pi restarts when Pidog goes into "stand"
Dear community,
Every time my pidog follows the “stand” prompt, the Raspberry Pi restarts.
I’ve checked everything I could think of, but I haven’t been able to identify the cause.
Has anyone experienced something similar, or does anyone have an idea what might be causing the restart?
Thanks in advance for your help!
What model of Raspberry Pi are you currently using?
The current version of Pidog is not compatible with the Pi 5.
We recommend that you operate it while the battery is adequately charged.
Could you please provide a video of the issue? This would help us analyze and resolve the problem more effectively.
Sorry for the late response. I believe I’ve found the cause of the restart issue: the micro HDMI cable was connected to the PiDog, and it seems that the movement of the cable (when the PiDog stood up) triggered the system to restart. Without the cable, there are no more restart problems.
It is not recommended to connect the HDMI cable to the display while running pidog, as it restricts the movement range of pidog.
