Raspberry Pi5 case for AI Fusion HAT
Has anyone found a best case that works with Raspberry pi 5 setup with AI Fusion Hat?
It would be ideal, if it also supports adding AI Fusion Hat camera gimbal as well.
Thanks in advance,
At the moment there is no dedicated case designed for the AI Fusion HAT, and the Pironman 5 MAX cannot accommodate the AI Fusion HAT — the internal space and structure of the case do not match, so we do not recommend building a Raspberry Pi 5 + AI Fusion HAT setup inside the Pironman 5 MAX.
That said, please don’t worry: the AI Fusion HAT comes with nylon standoffs. Once installed, they raise the Raspberry Pi 5 up, so you can simply use the board without an enclosure. Wiring, cooling, and mounting/adjusting the camera gimbal are all quite convenient this way, and it is sufficient for everyday use — a case is not strictly necessary.
For the actual physical assembly, please refer to the Quick User Guide in our official documentation:
If you still prefer a closed enclosure later on, you may follow our official forum and community, where other users share their own modification experiences. Please note that we have no official compatibility validation for such modifications, so you would need to evaluate them yourself.
